How to set an output that requires both switch and setpoint criteria?
Hi, I'm trying to control an I/O module to turn on/off some Heater relays based on some input temperatures and a set point. I've created a very basic Dashboard and some Node-RED logic to do this, and I am struggling to get the Heater output to require both a setpoint requirement and a switch to be on. I know that this could be done easily with an If statement, but I can't seem to get it to work. Any help would be greatly appreciated!
[{"id":"d59c70e9.a2416","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2b695eb3.2f03b2","type":"set-do-value","z":"d59c70e9.a2416","name":"T3 Heater Relay","write_ch":"0","write_ch_type":"write_do_1","x":740,"y":360,"wires":[["9950bc0e.6d425"]]},{"id":"71a698c0.f303a8","type":"set-do-value","z":"d59c70e9.a2416","name":"Fan Relay","write_ch":"2","write_ch_type":"write_do_1","x":730,"y":640,"wires":[[]]},{"id":"aac70c2a.51829","type":"ADAM-read","z":"d59c70e9.a2416","name":"","rate":"1000","host":"10.0.0.80","serialPortCfg":"","unit_id":1,"readDI":true,"readDO":false,"readAI":true,"readAO":true,"reconnecttimeout":"","mboutputStyle":"Multiple Outputs","Series":"mbtcp","advDevTypeTCP":"ADAM-6017","advDevTypeRTU":"ADAM-4015","advDevType":"ADAM-6017","outputs":8,"x":120,"y":260,"wires":[[],[],[],[],["c82b1905.573978"],["5d8f1d05.64d844"],["a8bb1b95.1f0978"],["a14406a9.3fb108"]]},{"id":"6ae35d37.94f0c4","type":"ui_numeric","z":"d59c70e9.a2416","name":"","label":"Enclosure Set Point","tooltip":"","group":"27fbd503.471f2a","order":4,"width":"5","height":"1","wrap":false,"passthru":false,"topic":"","format":"{{value}}","min":"0","max":"40","step":"2","x":330,"y":60,"wires":[["f657acc7.a60b1"]]},{"id":"d24103af.39722","type":"ui_switch","z":"d59c70e9.a2416","name":"","label":"Heater","tooltip":"","group":"27fbd503.471f2a","order":3,"width":"5","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":550,"y":580,"wires":[["f120373f.d1ee18"]]},{"id":"176de8d7.9e17e7","type":"ui_switch","z":"d59c70e9.a2416","name":"","label":"Fan","tooltip":"","group":"27fbd503.471f2a","order":2,"width":"5","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":550,"y":640,"wires":[["71a698c0.f303a8"]]},{"id":"f657acc7.a60b1","type":"change","z":"d59c70e9.a2416","name":"Set Point","rules":[{"t":"set","p":"setPoint","pt":"global","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Set Point","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":60,"wires":[["5d64787d.b727c8","5fb08e12.2ac9"]]},{"id":"c82b1905.573978","type":"change","z":"d59c70e9.a2416","name":"Interior T1","rules":[{"t":"set","p":"T1","pt":"global","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Interior T1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":180,"wires":[["794373e5.1bc21c"]]},{"id":"5d8f1d05.64d844","type":"change","z":"d59c70e9.a2416","name":"Interior T2","rules":[{"t":"set","p":"T2","pt":"global","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Interior T2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":220,"wires":[["38f32b3b.ba9514"]]},{"id":"a8bb1b95.1f0978","type":"change","z":"d59c70e9.a2416","name":"Exterior T3","rules":[{"t":"set","p":"T3","pt":"global","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Exterior T3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":260,"wires":[["95734680.01de78","94ea6bbd.e2cfd8"]]},{"id":"a14406a9.3fb108","type":"change","z":"d59c70e9.a2416","name":"Exterior T4","rules":[{"t":"set","p":"T4","pt":"global","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Exterior T4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":300,"wires":[["678daac2.037204","22a0e313.dd612c"]]},{"id":"794373e5.1bc21c","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":6,"width":"5","height":"1","name":"","label":"Interior T1","format":"{{msg.payload|number:2}} C","layout":"row-spread","x":570,"y":180,"wires":[]},{"id":"38f32b3b.ba9514","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":7,"width":"5","height":"1","name":"","label":"Interior T2","format":"{{msg.payload|number:2}}C","layout":"row-spread","x":570,"y":220,"wires":[]},{"id":"95734680.01de78","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":8,"width":"5","height":"1","name":"","label":"Exterior T3","format":"{{msg.payload|number:2}}C","layout":"row-spread","x":570,"y":260,"wires":[]},{"id":"678daac2.037204","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":9,"width":"5","height":"1","name":"","label":"Exterior T4","format":"{{msg.payload|number:2}}C","layout":"row-spread","x":570,"y":300,"wires":[]},{"id":"94ea6bbd.e2cfd8","type":"switch","z":"d59c70e9.a2416","name":"Set Point Decision","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"lowerBand","vt":"global"},{"t":"gte","v":"upperBand","vt":"global"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":380,"wires":[["f23da55c.424f58"],["7f5a830b.35794c"]]},{"id":"5d64787d.b727c8","type":"change","z":"d59c70e9.a2416","name":"Set Point Upper Band","rules":[{"t":"set","p":"upperBand","pt":"global","to":"$number($$.payload) + 2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":40,"wires":[[]]},{"id":"5fb08e12.2ac9","type":"change","z":"d59c70e9.a2416","name":"Set Point Lower Band","rules":[{"t":"set","p":"lowerBand","pt":"global","to":"$number($$.payload) - 2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":80,"wires":[[]]},{"id":"c7c8ad07.cedda","type":"inject","z":"d59c70e9.a2416","name":"","props":[{"p":"payload"}],"repeat":"1","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"setPoint","payloadType":"global","x":140,"y":60,"wires":[["6ae35d37.94f0c4"]]},{"id":"56eeb522.3276bc","type":"set-do-value","z":"d59c70e9.a2416","name":"T4 Heater Relay","write_ch":"1","write_ch_type":"write_do_1","x":740,"y":440,"wires":[["98b7ef3e.e4567"]]},{"id":"22a0e313.dd612c","type":"switch","z":"d59c70e9.a2416","name":"Set Point Decision","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"lowerBand","vt":"global"},{"t":"gte","v":"upperBand","vt":"global"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":420,"wires":[["5adc9330.1ac7ac"],["ee30cc48.79ea3"]]},{"id":"f23da55c.424f58","type":"change","z":"d59c70e9.a2416","name":"On","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":340,"wires":[["2b695eb3.2f03b2"]]},{"id":"7f5a830b.35794c","type":"change","z":"d59c70e9.a2416","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":380,"wires":[["2b695eb3.2f03b2"]]},{"id":"ee30cc48.79ea3","type":"change","z":"d59c70e9.a2416","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":460,"wires":[["56eeb522.3276bc"]]},{"id":"5adc9330.1ac7ac","type":"change","z":"d59c70e9.a2416","name":"On","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":420,"wires":[["56eeb522.3276bc"]]},{"id":"cba528fb.349a88","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":9,"width":0,"height":0,"name":"","label":"T3 Heater","format":"{{msg.payload}}","layout":"row-spread","x":1120,"y":360,"wires":[]},{"id":"9950bc0e.6d425","type":"change","z":"d59c70e9.a2416","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"On","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"Off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":360,"wires":[["cba528fb.349a88"]]},{"id":"98b7ef3e.e4567","type":"change","z":"d59c70e9.a2416","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"On","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"Off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":440,"wires":[["d7803183.89fd4"]]},{"id":"d7803183.89fd4","type":"ui_text","z":"d59c70e9.a2416","group":"27fbd503.471f2a","order":9,"width":0,"height":0,"name":"","label":"T4 Heater","format":"{{msg.payload}}","layout":"row-spread","x":1120,"y":440,"wires":[]},{"id":"f120373f.d1ee18","type":"change","z":"d59c70e9.a2416","name":"","rules":[{"t":"set","p":"heater","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":580,"wires":[[]]},{"id":"e5b51612.54d648","type":"inject","z":"d59c70e9.a2416","name":"","props":[{"p":"payload"}],"repeat":"1","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"heater","payloadType":"global","x":380,"y":580,"wires":[["d24103af.39722"]]},{"id":"27fbd503.471f2a","type":"ui_group","name":"Controls","tab":"20d4bd59.a21a22","order":1,"disp":true,"width":"5","collapse":false},{"id":"20d4bd59.a21a22","type":"ui_tab","name":"Home","icon":"dashboard","order":2,"disabled":false,"hidden":true}]
In order to be able to access both setpoint and the switch state at the same time you need to get them both into one message. You can do that using a Join node in key/value mode. See this article in the cookbook for an example of how to join messages into one object.
