How to set the _field tag to write to influxdb using the influxdb out node?
Hey everyone,
I'm new to node-red and already learned a lot from browsing this forum.
I have a little flow that right now uses a single object to write a value into influx db using the influxdb out node.
My problem is, that the entries made in influxdb have _value as the _field tag where I want it do be AT and I don't get why that is. The object send to the influxdb out node is
grafik
I am thankful for hints and ideas and happy to learn.
Welcome to the forum @HerrLux
As described in the help text for the node, you can pass on object in msg.payload with the property AT set to the value.
You do that in a Change node configured like this
Then feed that into a Debug node to make sure it looks right before connecting to the Influx node.
Thank you very much Colin.
In between your two replies I came up with a function note that does the trick for me
msg.payload = [{
       "AT": msg.payload,
If you want to do it in a function (which is less efficient than a change node) then you can take out the square brackets. It doesn't need to be an array. Again, see the help text for the node.
