How to share sub-flows as Pallet?
Hi our team is currently working on a project where we have created few sub-flows for specific functions. We share sub-flows through JSON as of now.
But we are thinking to move to sharing the sub-flows where it cannot be edited/changed to prevent any issue.
So I am curious to know if there is any way we can share them by converting it to a pallet (such as function, http etc.) without publishing it publicly as of now.
Or is there any imminent feature to be added in Node-RED which might help in this regard?
Welcome to the forum @Arnab
Generally it is best to start with the official Node-RED documentation.
https://nodered.org/docs/creating-nodes/subflow-modules
Hi @TotallyInformation Thank you.
I have tried to convert a sub-flow to a node with this method.
The issue i am facing is that the input and output nodes are not showing on the converted node.
Can you please help me with what I have to do to have the input/output working?
Previously it was like this:
I've never tried to share sub-flows that way but have used them extensively.
The input / output 'ports' (connection points) are controlled in the subflow properties dialog:
Set input = 1 and output = however many are needed / relevant.
I hope that helps.
Cheers,
Paul
You shouldn't need to anything beyond what the docs describe.
Can you share a copy of the subflow json you've created using the instructions in the docs?
Here it it, stripped down the code a little bit:
  "id": "31ac1d10.6d4e72",
  "type": "function",
  "z": "a426e26b.67424",
  "name": "Create Postprocessing Info",
  "func": "return msg;",
  "outputs": 1,
  "noerr": 0,
  "initialize": "",
  "finalize": "",
  "libs": [],
  "x": 320,
  "y": 80,
  "wires": [[]],
  "flow": [
      "id": "a426e26b.67424",
      "type": "subflow",
      "info": "",
      "category": "SPPA",
      "in": [{ "x": 40, "y": 80, "wires": [{ "id": "31ac1d10.6d4e72" }] }],
      "out": [
        { "x": 580, "y": 80, "wires": [{ "id": "31ac1d10.6d4e72", "port": 0 }] }
      "env": [{ "name": "Name", "type": "str", "value": "Processor" }],
      "meta": {
        "module": "create-postprocessing-info",
        "version": "1.1.0",
        "author": "...",
        "desc": "A node to stack up the msg.Message.IoT structure with a describing name and timestamp when the node was passed."
      "color": "#6090ff"
Hi @Arnab
that JSON is not correct. You have a function node at the top level and the subflow node inside the flow property. It should be the other way around.
Hi @knolleary it worked! Thank you a lot.
