How to simply write/read signed and unsigned values
Hello
I have a ventilation system which is using RTU modbus to communicate.
Some of values are signed and others unsigned.
I can read unsigned values, default config of Modbus-contrib. I am not sure that it's working properly for signed values since it's the outside temperature and actually it is positive.
How to parameter the node to read signed values?
Tx
Antoine
There is a contrib designed for simplifying this. It contains a parser and maker node.
node-red-contrib-buffer-parser
[{"id":"f5410105eecb8283","type":"inject","z":"85e1791bc0cd6285","name":"write 16001.5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"16001.5","payloadType":"num","x":1020,"y":440,"wires":[["f958f283b7aadc13"]]},{"id":"bc8160dfb8d6553a","type":"buffer-parser","z":"85e1791bc0cd6285","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint16be","name":"item1","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1410,"y":440,"wires":[["597e975260b85355"]]},{"id":"597e975260b85355","type":"debug","z":"85e1791bc0cd6285","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload[0]","targetType":"msg","statusVal":"payload","statusType":"auto","x":1400,"y":500,"wires":[]},{"id":"f958f283b7aadc13","type":"buffer-maker","z":"85e1791bc0cd6285","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"floatbe","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":1220,"y":440,"wires":[["bc8160dfb8d6553a"]]}]
