I have a data object in the real-time database. I want to retrieve the object's contents, namely the pump and timestamp, and display the data in a table. How do I do it? What nodes should I install? thank you
You need to change the format of your data to match the expected format of the ui_table.
the help shows you an example...
You can achieve this in the built in nodes
e.g. a function node or possibly a change node (using JSONata) or a combination of split --> join nodes
Thank you very much for helping, bu I still don't understand how to separate object id (MFI *********), and there is a constraint where I can't change the data format in firebase
You dont need to change the format of your database. You use Javascript (in a function) or JSONata or a combination of split and join nodes. Did you try any of these?
post some sample data in a reply by copying the data from the debug
like this...
then post it in a reply
paste the copied data between backticks like this
