What do these commands show?
which node
which npm
apt policy nodejs
apt policy npm
It is not a problem, ignore it.
which node
which npm
apt policy nodejs
apt policy npm
Don't worry, we all get that.
Reply:
pi@TimePi:~/.node-red $ which node
/usr/bin/node
pi@TimePi:~/.node-red $ which npm
/usr/bin/npm
pi@TimePi:~/.node-red $ apt policy node.js
node-jstimezonedetect:
Installed: (none)
Candidate: 1.0.6-2
Version table:
1.0.6-2 500
500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
node-json-buffer:
Installed: (none)
Candidate: 3.0.0-1
Version table:
3.0.0-1 500
node-json-localizer:
Installed: (none)
Candidate: 0.0.3-1
Version table:
0.0.3-1 500
node-json-stable-stringify:
Installed: (none)
Candidate: 1.0.1-1
Version table:
1.0.1-1 500
node-json-schema-traverse:
Installed: (none)
Candidate: 0.3.1-1
Version table:
0.3.1-1 500
node-jszip-utils:
Installed: (none)
Candidate: 0.0.2+dfsg-1
Version table:
0.0.2+dfsg-1 500
node-jsv:
Installed: (none)
Candidate: 4.0.0+ds1-1
Version table:
4.0.0+ds1-1 500
node-jsonstream:
Installed: (none)
Candidate: 1.3.2-1
Version table:
1.3.2-1 500
node-json-schema:
Installed: (none)
Candidate: 0.2.3-1+deb10u1
Version table:
0.2.3-1+deb10u1 500
node-js-cookie:
Installed: (none)
Candidate: 2.2.0-2
Version table:
2.2.0-2 500
node-jsdom:
Installed: (none)
Candidate: 0.8.10+dfsg1-1
Version table:
0.8.10+dfsg1-1 500
node-jsesc:
Installed: (none)
Candidate: 2.5.2-1
Version table:
2.5.2-1 500
node-json-stringify-safe:
Installed: (none)
Candidate: 5.0.1-1
Version table:
5.0.1-1 500
node-json3:
Installed: (none)
Candidate: 3.3.2-1
Version table:
3.3.2-1 500
node-json5:
Installed: (none)
Candidate: 0.5.1-1+deb10u1
Version table:
0.5.1-1+deb10u1 500
node-json-parse-better-errors:
Installed: (none)
Candidate: 1.0.2-2
Version table:
1.0.2-2 500
node-js-yaml:
Installed: (none)
Candidate: 3.11.0+dfsg-1
Version table:
3.11.0+dfsg-1 500
node-jssip:
Installed: (none)
Candidate: 0.6.34-5
Version table:
0.6.34-5 500
node-json-loader:
Installed: (none)
Candidate: 0.5.4-1
Version table:
0.5.4-1 500
node-jsonminify:
Installed: (none)
Candidate: 0.4.1+dfsg1-1
Version table:
0.4.1+dfsg1-1 500
node-jsprim:
Installed: (none)
Candidate: 1.4.0-1
Version table:
1.4.0-1 500
node-jsonselect:
Installed: (none)
Candidate: 0.4.0+dfsg3-1
Version table:
0.4.0+dfsg3-1 500
node-jsonfile:
Installed: (none)
Candidate: 5.0.0-1
Version table:
5.0.0-1 500
node-jsonparse:
Installed: (none)
Candidate: 1.3.1-6
Version table:
1.3.1-6 500
node-json2module:
Installed: (none)
Candidate: 0.0.3-1
Version table:
0.0.3-1 500
node-jszip:
Installed: (none)
Candidate: 3.1.4+dfsg-1+deb10u1
Version table:
3.1.4+dfsg-1+deb10u1 500
node-jsonify:
Installed: (none)
Candidate: 0.0.0-1
Version table:
0.0.0-1 500
node-jschardet:
Installed: (none)
Candidate: 1.6.0+dfsg-3
Version table:
1.6.0+dfsg-3 500
node-js-tokens:
Installed: (none)
Candidate: 2.0.0-1
Version table:
2.0.0-1 500
node-js-beautify:
Installed: (none)
Candidate: 1.7.5+dfsg-3
Version table:
1.7.5+dfsg-3 500
node-json-parse-helpfulerror:
Installed: (none)
Candidate: 1.0.3-2
Version table:
1.0.3-2 500
node-jsbn:
Installed: (none)
Candidate: 1.1.0-1
Version table:
1.1.0-1 500
node-jsonld:
Installed: (none)
Candidate: 1.5.3-1
Version table:
1.5.3-1 500
pi@TimePi:~/.node-red $ apt policy npm
npm:
Installed: (none)
Candidate: 5.8.0+ds6-4+deb10u2
Version table:
5.8.0+ds6-4+deb10u2 500
It is kind of the ...... main machine.
I guess I could update it, but.......
I'd have to remember all the stuff I've got installed on it and install them on the new build.
(Not the end of the world.)
I updated form ...... jessie to buster a few years ago.
(just mentioning)
Everything was working and I was editing code in a subflow.
DEPLOY..... (wait wait wait)..... no response from server.
The details are important when entering commands
Yup, been there, done that. I still have one Pi running Bullseye.
Probably best to concentrate on NR just now.
There was a time when you had to install npm seperately but I think that was back at Wheezy.
"Everything was working" Hmm something broke, let's hope it's not the SD card failing.
Stepping back while Colin diagnoses...
I hope the SD card isn't on it's way out.
Haven't had any other problems. I was just .... stupidly ..... trying to get a bit of code working.
Did you see my last post?
Yes, but I do not know what it means.
So wasn't sure if it was a question or statement.
I posted
You mistyped the third one.
Sorry.
Finger nails are long.
I slightly changed the order only that they are
which node
which npm
apt policy npm
apt policy nodejs
Only that their outputs are small to large.
/usr/bin/node
/usr/bin/npm
npm:
Installed: (none)
Version table:
pi@TimePi:~/.node-red $ apt policy nodejs
nodejs:
Installed: 20.19.0-1nodesource1
Candidate: 20.19.0-1nodesource1
Version table:
*** 20.19.0-1nodesource1 500
500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
100 /var/lib/dpkg/status
20.18.3-1nodesource1 500
20.18.2-1nodesource1 500
20.18.1-1nodesource1 500
20.18.0-1nodesource1 500
20.17.0-1nodesource1 500
20.16.0-1nodesource1 500
20.15.1-1nodesource1 500
20.15.0-1nodesource1 500
20.14.0-1nodesource1 500
20.13.1-1nodesource1 500
20.13.0-1nodesource1 500
20.12.2-1nodesource1 500
20.12.1-1nodesource1 500
20.12.0-1nodesource1 500
20.11.1-1nodesource1 500
20.11.0-1nodesource1 500
20.10.0-1nodesource1 500
20.9.0-1nodesource1 500
20.8.1-1nodesource1 500
20.8.0-1nodesource1 500
20.7.0-1nodesource1 500
20.6.1-1nodesource1 500
20.6.0-1nodesource1 500
20.5.1-1nodesource1 500
20.5.0-1nodesource1 500
20.4.0-1nodesource1 500
20.3.1-1nodesource1 500
20.3.0-1nodesource1 500
20.2.0-1nodesource1 500
20.1.0-1nodesource1 500
20.0.0-1nodesource1 500
10.24.0~dfsg-1~deb10u3 500
It was only the one you mistyped originally that we needed.
That all looks ok, what about
node -v
npm -v
pi@TimePi:~/.node-red $ node -v
node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
pi@TimePi:~/.node-red $ npm -v
Make sure all your os packages are up to date
sudo apt update && sudo apt full-upgrade
Then try the -v commands again.
pi@TimePi:~/.node-red $ sudo apt update && sudo apt full-upgrade
Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I realise it isn't that, nodejs 18 is the latest supported for buster, so re-run the script but with --node18 instead of 20
Don't you keep image backups of all your SD cards? If not then you should. Then when one fails you just need to re-burn it on a new card.
Try it, run
node-red-start
