Hello everyone,
I am developing software to help program microcontroller boards and I want to integrate Node-RED into my Electron application to retrieve data sent by my boards.
I used the example code (https://nodered.org/docs/user-guide/runtime/embedding) and it works fine, but I can't find how to stop the Node-Red runtime (the RED.stop() command doesn't stop anything) or even the express server. I have the impression that it's the same solution everywhere: close the application window. But this is not a solution in my opinion...
I would like the user to be able to launch a popup (node-red launches in the background) and close it (and thus close node-red and the express server). This seems impossible...
I tried to list the connections to close them one by one but it doesn't work, I tried to replace Express with Fastify but the problem is the same. In short....HELLLLPPP !!!!
Thank you very much in advance.
