How to subscribe to multiple clients in websocket node
I am customizing websocket node for subscribing to multiple comma separated node. I found the source code https://github.com/node-red/node-red/blob/master/test/nodes/core/network/22-websocket_spec.js but how can I modify the code for custom websocket client creation.
Using an editor ?
You found the test case file for it. The actual source for the node is here - node-red/packages/node_modules/@node-red/nodes/core/network/22-websocket.js at master · node-red/node-red · GitHub
not using editor using using custom node.
