How to tackle this one
This is a slightly better layout for simplicity
[{"id":"19c34f22.1b1c29","type":"inject","z":"fc6fbf47.86d3e8","name":"Reset","props":[{"p":"reset","v":"true","vt":"bool"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":100,"y":70,"wires":[["37176db4.a7f91a"]]},{"id":"37176db4.a7f91a","type":"trigger","z":"fc6fbf47.86d3e8","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-4","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":320,"y":120,"wires":[["a432b8a8.5d82f8","3d921823.47e428"]]},{"id":"b4da3c74.87be","type":"inject","z":"fc6fbf47.86d3e8","name":"Start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":120,"wires":[["37176db4.a7f91a"]]},{"id":"ee8f2dd5.12e408","type":"debug","z":"fc6fbf47.86d3e8","name":"Toggle","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":620,"y":60,"wires":[]},{"id":"a432b8a8.5d82f8","type":"function","z":"fc6fbf47.86d3e8","name":"","func":"var x = context.get(\"toggle\") || 0;\n\nx = x + 1;\ncontext.set(\"toggle\",x);\n\nx = x%2;\n\nmsg.payload = x;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":120,"wires":[["ee8f2dd5.12e408","ee454ba6.42219"]]},{"id":"ee454ba6.42219","type":"change","z":"fc6fbf47.86d3e8","name":"From sensor","rules":[{"t":"set","p":"state","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":120,"wires":[[]]},{"id":"35f098ff.4fb488","type":"inject","z":"fc6fbf47.86d3e8","name":"ON","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"ON","payloadType":"str","x":110,"y":320,"wires":[["b28cf4b.2c00488","fed734ce.1e307"]]},{"id":"f5718044.5024b8","type":"inject","z":"fc6fbf47.86d3e8","name":"STANDBY","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"SB","payloadType":"str","x":130,"y":370,"wires":[["b28cf4b.2c00488"]]},{"id":"6c2170b7.e9e3b8","type":"comment","z":"fc6fbf47.86d3e8","name":"Standby output simulation","info":"","x":390,"y":80,"wires":[]},{"id":"3d921823.47e428","type":"link out","z":"fc6fbf47.86d3e8","name":"CLOCK","links":["b9d287f.affa178","985ea4bd.4fa2c"],"x":315,"y":170,"wires":[]},{"id":"b9d287f.affa178","type":"link in","z":"fc6fbf47.86d3e8","name":"CLOCK","links":["3d921823.47e428"],"x":395,"y":450,"wires":[["e13828e9.c4d01"]]},{"id":"e13828e9.c4d01","type":"change","z":"fc6fbf47.86d3e8","name":"get flow.mode","rules":[{"t":"set","p":"payload","pt":"msg","to":"mode","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":450,"wires":[["3c8ab0e3.681ca","cc0ca5de.84be78"]]},{"id":"b28cf4b.2c00488","type":"change","z":"fc6fbf47.86d3e8","name":"set flow.mode","rules":[{"t":"set","p":"mode","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":370,"wires":[[]]},{"id":"3c8ab0e3.681ca","type":"switch","z":"fc6fbf47.86d3e8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"SB","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":660,"y":450,"wires":[["bd7a1ca4.678a8"],["8cd6ae25.5b20c"]]},{"id":"fed734ce.1e307","type":"change","z":"fc6fbf47.86d3e8","name":"SET ON","rules":[{"t":"set","p":"state","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":320,"wires":[[]]},{"id":"cc0ca5de.84be78","type":"debug","z":"fc6fbf47.86d3e8","name":"MODE","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":510,"y":500,"wires":[]},{"id":"bd7a1ca4.678a8","type":"delay","z":"fc6fbf47.86d3e8","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":820,"y":390,"wires":[["7064a5d7.dd19b4"]]},{"id":"f745622e.2022d","type":"change","z":"fc6fbf47.86d3e8","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":500,"wires":[["bd7a1ca4.678a8"]]},{"id":"8cd6ae25.5b20c","type":"switch","z":"fc6fbf47.86d3e8","name":"SB?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SB","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":670,"y":500,"wires":[["f745622e.2022d","2cbf2225.cba0b6"]]},{"id":"a110a4c1.746968","type":"debug","z":"fc6fbf47.86d3e8","name":"Output","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1150,"y":450,"wires":[]},{"id":"2cbf2225.cba0b6","type":"change","z":"fc6fbf47.86d3e8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"SB","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":540,"wires":[["7064a5d7.dd19b4"]]},{"id":"7064a5d7.dd19b4","type":"rbe","z":"fc6fbf47.86d3e8","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":1000,"y":450,"wires":[["a110a4c1.746968"]]},{"id":"333d8883.05e518","type":"comment","z":"fc6fbf47.86d3e8","name":"Mode selecter (by device)","info":"","x":250,"y":270,"wires":[]}]
Wow i am going to have to sit down and go through this and see what you have done - thanks for all the effort.!!
Craig
no problems.
Good luck.
Most of the nodes are to set up the scenario.
Only the bottom part is the bit that does what you want.
The one for the problem i put up about the Heatpump and sensing what state it was in ??
Yep worked my way through it and understood it - was quite nice work thanks.
It was a bit of overkill for what i needed (and hence has extra complexity) in the end the one i put up with the trigger node worked - just had to reverse the states on it - so ended up being 3 nodes - here it is
[{"id":"1629a54e.99ed5b","type":"change","z":"9ca52a8a.d12d48","name":"Check for Standby Mode","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.dps[\"115\"]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":360,"wires":[["654c0af3.188134"]]},{"id":"e7144c41.5704","type":"ui_text","z":"9ca52a8a.d12d48","group":"624acab0.30b154","order":3,"width":"3","height":"1","name":"","label":"Operating mode","format":"{{msg.payload}}","layout":"col-center","x":1120,"y":440,"wires":[]},{"id":"6981e1a9.1c385","type":"trigger","z":"9ca52a8a.d12d48","name":"Send Running Status of HeatPump","op1":"Standby","op2":"Running","op1type":"str","op2type":"str","duration":"15","extend":true,"units":"s","reset":"4","bytopic":"all","topic":"topic","outputs":1,"x":880,"y":500,"wires":[["e7144c41.5704","ce829411.bb15f8"]]},{"id":"654c0af3.188134","type":"rbe","z":"9ca52a8a.d12d48","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":790,"y":420,"wires":[["6981e1a9.1c385"]]},{"id":"ce829411.bb15f8","type":"change","z":"9ca52a8a.d12d48","name":"Set Global Variable for HP State","rules":[{"t":"set","p":"HeatPump.Status","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":520,"wires":[[]]},{"id":"624acab0.30b154","type":"ui_group","z":"","name":"Heat Pump Reporting","tab":"720f2dcc.ee59b4","order":5,"disp":true,"width":"18","collapse":true},{"id":"720f2dcc.ee59b4","type":"ui_tab","z":"","name":"Heating Controls","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
Craig
