Safety node via function node —need help!
Hello everyone,
i‘m new in programming.
For my project i would need a function with an „if/or“ rule.
i have 2 hysteresis nodes from my two warm- supply.
so if one or both of them sends „on“, „1“, „true“.. i need to put the pump on.
only when both are off, 0 or false the pump should be of.
right now if the pump is on & the the lower hysteresis reaches the lower point the pump shuts off & my solar-panel is overheating..
i hope that somebody could help me,
thanks in advance!
-ruppi
Hi @ruuuppi - welcome to the forums.
This is a quick drive by visit.
I would use something like a boolean logic node (in OR operation)
Here is my fav.
It will return true i.e turn on pump, if at least one of your inputs values are true, else it will return false
Export
[{"id":"83aed8db904ad634","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"45c4d08af0e5f693","type":"BooleanLogicUltimate","z":"83aed8db904ad634","name":"","payloadPropName":"payload","filtertrue":"both","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"trigger","outputtriggeredby":"all","inputCount":2,"topic":"result","restrictinputevaluation":false,"delayEvaluation":0,"x":415,"y":215,"wires":[[],["038f7b9567c2f923"],[]]},{"id":"d15a5d27d62ea02a","type":"inject","z":"83aed8db904ad634","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Hysteresis1","payload":"true","payloadType":"bool","x":230,"y":135,"wires":[["45c4d08af0e5f693"]]},{"id":"e4d33954d05569a7","type":"inject","z":"83aed8db904ad634","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Hysteresis1","payload":"false","payloadType":"bool","x":230,"y":180,"wires":[["45c4d08af0e5f693"]]},{"id":"32084b8614fdc479","type":"inject","z":"83aed8db904ad634","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Hysteresis2","payload":"true","payloadType":"bool","x":220,"y":280,"wires":[["45c4d08af0e5f693"]]},{"id":"eb4af54ebdf4f705","type":"inject","z":"83aed8db904ad634","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Hysteresis2","payload":"false","payloadType":"bool","x":220,"y":325,"wires":[["45c4d08af0e5f693"]]},{"id":"038f7b9567c2f923","type":"debug","z":"83aed8db904ad634","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":215,"wires":[]},{"id":"3f05eab285965fd3","type":"comment","z":"83aed8db904ad634","name":"Turn on pump?","info":"","x":790,"y":175,"wires":[]}]
Hello @marcus-j-davies,
thanks for your help - it works perfectly now!
Best regards!
-ruppi
