Help needed with comparing inputs using msg.topic
I have a system where there are 8 inlet pressure measurements from 8 different channels. In my system, I am trying to maintain the pressure in a range using hysteresis.
Here, I want the compressor to switch on even if one of 8 pressure measurement drop below a certain value (say 0.2 bar). But, I tried to connect the one output to the compressor from each input. Then realized that multiple inputs from my 8 channels are to be in a OR function to run the compressor even if one of the pressure channels are below pressure.
How can I separate the hysteresis output from each of the 8 channels to get an output turn on even if one of the pressure falls below?
I tried using msg.topic but I am making some mistake as I couldn't compare the topics.
8 channels read pressure - 8 hysteresis loops for each channel - write the output (switch on) the compressor even when one value is below set point.
I assume you receive 8 different messages, node-red handles a single message at a time, you can combine the messages using a join node. Or use context to keep track of all values and compare.
I used global context to assign the output to a varuiable and used it for control. Thank you.
But when I use join node to form an array of the 8 inputs, how can I check if at least one of the input is 1 or ON??
Don't use array mode on the join node, use key/value mode. Then it's a simple case of logic in a function node.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
If you already have the 8 channels and 8 hysteresis nodes set to provide a 1 if they need to be switched on then you don't need anything fancy, as any node outputting a 1 should be aa signal to act - not matter where it comes from... so just wire all of them into a node that just looks for a 1... or am I missing something ?
Possibly there needs to be a way of getting back to zero again when none of the inputs is on.
Presumably you would run for a timeout. You wouldn’t want to oscillate a compressor on/off around a set point
Hence the hysteresis nodes.
Ithank you very much for the replies. Though I found a method, I happen to have better understand on how to improve it.
I thought having multiple inputs to one node to switch on the compressor might have contradicting signal. When I instead of having one particular output node, had 8 separate nodes that pointed to my compressor, it got on for one second or so and switched off later.
This is something that can be avoided if I have one compressor node and 8 inputs going to it (instead of 8 comp, and 8 nodes)?
I don't understand what you mean. Can you post the flow for what you have so far please so that I can better understand? So from the pressure inputs through to the compressor output. See this post for how to post your flow - How to share code or flow json
I could not reply to you as I had met with an accident and was not able to work!
Thank you for answering anyways and I found that my flow had an issue may be due to the node red version of it (v0.17.5).
Multiple inputs with opposite values for eg: 0 and 1 are the inputs to the particular node with operates the blower in my system. But, when varying inputs are given, the blower shuts off after starting for a second or so. So, I used a function with OR statement to give me an output of either 0 or 1.
[{"id":"79df6e65.866f","type":"function","z":"eda27e78.828a9","name":"OR from Inputs","func":"var A71  = global.get('A71');\n\nvar A72  = global.get('A72');\n\nvar A73  = global.get('A73');\n\nvar A50  = global.get('A50');\n\nvar A51  = global.get('A51');\n\nvar A30  = global.get('A30');\n\nvar A31  = global.get('A31');\n\nvar A32  = global.get('A32');\n\nif (A71 == 1 || A72 == 1 || A73 == 1 || A51 == 1 || A50 == 1 || A30 == 1 || A31 == 1 || A32 == 1 ){\n    msg.payload=1;\n}\nreturn msg;","outputs":1,"noerr":0,"x":470.00006103515625,"y":2744.5002641677856,"wires":[["6af1ce00.8678e4"]]}]
