hey , I generated a csv values for a json data , now how can I make it a csv file and then upload to my google drive ? I have been trying to use google drive node , but when I create a file using create file operation it just creates but an empty file . theres a content field while configuring but how do I pass a value over there ?
Hi and welcome.
Can you create a example flow with test data in an inject node, and export it here.
What is the google node you are using a link to the nodes read me would be helpful in helping you.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
