Hi Community,
I'm new to node red and I'm trying to upload a file in the Http request, It is looking different from doing in postman,
Any help or guidance would be invaluable
Did you try out any of the flow examples here: Library - Node-RED
Or check out the forum: Search results for 'http request file upload order:latest' - Node-RED Forum
Hi @Steve-Mcl ,
Thanks for your Suggestion,
I have found a thread for file upload scenario
Which has given me a path to resolve this as below
var base64Data = msg.encodedFile;
var buffer = Buffer.from(base64Data, 'base64');
var formData = {
    file: {
        value: buffer,
        options: {
            filename: `${msg.fileName}`,
            contentType:`${msg.fileType}`
