Some one can guild line me for uplaod or insert pdf file to sql database
do you know how do insert data into an sql database? If you don't do a google search using 'node-red mysql example' and you find a tutorial.
does your database have a column defined as 'blob'? If you don't, do a google search using 'sql blob' and read about what you need to define in the database to store a large file. Then check the schema of your database and make sure to add one. depending on if this is afor a business, you may have to talk to your DBA. If not, you'll need to create the table with that data type.
Hi. That is a fairly loaded question.
Before we can assist, you really need to share more info.
for example...
- Where are you stuck?
- Do you have the "Upload" part working?
- Do you have the SQL Server
INSERTpart working? - Do you have the Database and its Tables created already?
- Are you expecting to use SQL Stored Procedures or INSERT queries?
- Are you wanting to upload the text from the PDF (into a text field) OR the actual file (as a blob?)
- what SQL Server version are you using?
- is the SQL Server local or remote
- are you using built-in security or SQL Server logins?
- Are you using
node-red-contrib-mssql-plus(this is the most capable / most supported node)
[quote="Steve-Mcl, post:3, topic:58886"]
ํYes, - Do you have the SQL Server
INSERTpart working?
Yes, using node red. - Do you have the Database and its Tables created already?
No, please recommend data type. - Are you expecting to use SQL Stored Procedures or INSERT queries?
Just INSERT queries. - Are you wanting to upload the text from the PDF (into a text field) OR the actual file (as a blob?)actual file .pdf
what SQL Server version are you using?ver 2014 express. - is the SQL Server local or remote: Local
- are you using built-in security or SQL Server logins? No need
- Are you using
Yes using node mssql-plus.
