How to use a message variable to navigate an array that is also a message variable, in a change node?
Hey there,
I'm struggling trying to use a message variable to navigate an array that is also a message variable, in a change node, as follows:
I tried the following, but nothing works:
msg.months[msg.index]
msg.months[index]
msg.months[$.index]
msg.months[$$.index]
What am I doing wrong?
Ah!
Just got it working by using twice the $$ as follows:
$$.months[$$.index]
There is no need for JSONata in simple cases like this, you can use array syntax...
(requires newish version of node-red)
