How to use flow variabile without modifing it
Hi all, can anyone explain to me why the flow's variable created with the first inject node is modified in the other two without using the flow.set() method?
[{"id":"26a58557.18feca","type":"inject","z":"938038fa.b84288","name":"Make a flow variable","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"IdDispositivo\":8,\"SystemGroup\":\"OLCIS\",\"IP\":\"192.168.1.132\",\"ShutdownDelay\":\"0\"}","payloadType":"json","x":170,"y":100,"wires":[["9a5d3c3a.80b9f"]]},{"id":"c566479c.b8dae8","type":"function","z":"938038fa.b84288","name":"setFlow.DeviceToPayload","func":"let x = flow.get('device')||0;\nlet payload = x;\npayload.count = 0;\nreturn {payload};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":190,"y":400,"wires":[[]]},{"id":"9a5d3c3a.80b9f","type":"change","z":"938038fa.b84288","name":"","rules":[{"t":"set","p":"device","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":160,"wires":[[]]},{"id":"a3defa86.57a188","type":"inject","z":"938038fa.b84288","name":"take flow variable to use it in the msg without modifing flow variable","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":280,"y":220,"wires":[["72dde4c6.6c969c"]]},{"id":"72dde4c6.6c969c","type":"change","z":"938038fa.b84288","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"device","tot":"flow"},{"t":"set","p":"payload.count","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":280,"wires":[[]]},{"id":"6560276b.544388","type":"inject","z":"938038fa.b84288","name":"Do the some but in a function","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":160,"y":340,"wires":[["c566479c.b8dae8"]]}]
Because JS objects are copied and stored by reference
Clone the message
https://nodered.org/docs/api/modules/v/1.3/@node-red_util_util.html
let payload = RED.util.cloneMessage(x);
payload.count = 0;
return {payload};
OK! I got it
now ther's a new problem
My fault typo on "Red" should be "RED"
