Hi there,
i like to use a function node to bring incomming messages to a global value.
Hard for me to discribe, as the problem seems to be very rare. Lets try:
My recent code:
var name = msg.channelName;
var status = msg.payload;
global.set('name', status)
The "name" in the global.set context should be the var from above. And I have no idea how the right code shoud look like.
Any hints?
Best wishes
bibi
I don't see any problems here. If it stays that simple a normal "change" node would do the job too.
During testing be sure to refresh the display of globals on the right window. I had this stupid mistake once and where wondering about the status of my global variables.
bibi-b:
My recent code:
Remove the quotes...
//global.set('name', status); // << wrong
global.set(name, status); // << correct
Changed to this:
and getting this error:
Error: Invalid property expression: unexpected ' ' at position 10
Change code to this...
node.warn("name = " + name );
node.warn("status = " + status );
what do you see in debug side bar?
oh stop. the "status" is sometimes boolean, sometimes a string (0 or 1). Maybe that ist why?
bibi-b:
Maybe that ist why?
No, you can store bool/string/object/whatever in the global context.
It is the name that is important - it must be a non zero length string
Maybe because of the spaces in name?
no, spaces are valid in the name.
Are you still getting an error? Have you checked the context data side bar panel? Have you presed the refresh button?
Steve-Mcl:
yes, i did. Can you see the screenshot i uploaded from the sidebar? if not:
name = Schlafzimmer Fenster
status = 1
name = Wohnzimmer links Tür
status = 0
... and so on. Seems to be correct.
bibi-b:
Seems to be correct
So it is working now?
Is there anything in the context data view like I showed
Steve-Mcl:
No
Here is the second screen with the errors:
Colin
25 June 2021 08:19
13
I thought that too, but testing, even with a fixed string, does give an error
global.set("some string", "test")
gives the error that @bibi-b is seeing (but at position 4)
Wow, could have sworn I tested that - you are right colin lol
@bibi-b you will have to remove spaces from the names OR use an object to store the values in then store the object.
Thank you both!
Do you have a quick code i can insert in the function node to change spaces to an underscore _ ?
Try this instead first - you might find it preferable to having hundreds of top level global variables - especially if you want to deleted them all in one go...
const channelData = global.get("channelData") || {};
const name = msg.channelName;
const status = msg.payload;
channelData[name] = status;
global.set("channelData", channelData);
Working perfectly. Thanks a lot for your time and help!
