Hi everyone, I've only just learned to use node-red a short while ago and don't know much about Javascript (but I can get AI to help).
I would like to ask a question:
I have a total of 6 data to upload to Modbus Server now, but later I will plan to upload ten and more data, if I still follow the current method, it will make the work cost more. What is the best way to increase the efficiency?
Below is my flow:
"id": "a021a58553f87da9",
"type": "tab",
"label": "物联网 demo 测试",
"disabled": false,
"info": "",
"env": []
"id": "1964653c8868349d",
"type": "group",
"z": "a021a58553f87da9",
"style": {
"stroke": "#999999",
"stroke-opacity": "1",
"fill": "none",
"fill-opacity": "1",
"label": true,
"label-position": "nw",
"color": "#a4a4a4"
"nodes": [
"db194b3a981add30",
"d6bd6820cc9c86c4",
"2d11710d8950e6b0",
"ca5832a1a8687599",
"3dacf9589ea47ed6",
"baf7dab8bc12de02",
"657b712d240c8b9e",
"4083025c0899d485",
"49c68e7312599925",
"91406028333b4757",
"0f9d16a881e6d926",
"722bbb3ff5d8c3ab"
"x": 254,
"y": 79,
"w": 872,
"h": 422
"id": "3c4c8ee1c0e8b06f",
"type": "group",
"style": {
"fill": "none",
"label": true,
"color": "#a4a4a4"
"nodes": [
"84425a7eb012ce1e",
"dea8d86c68bb5e34",
"972d12e07fdac55a",
"5e24e053f497b8d6",
"19514fe8f6cbd369",
"561d7e41803d66fe"
"x": 254,
"y": 519,
"w": 692,
"h": 242
"id": "b091717ec90e710f",
"type": "group",
"style": {
"fill": "none",
"label": true,
"color": "#a4a4a4"
"nodes": [
"aed82866809e0eb3",
"fa6698a7a0c342ef",
"6219c63f8289f41c",
"2330626e4eac6a89",
"381ebb1a749733e7",
"4872de3d7499e5cb",
"c4a7cc7ba8e9e048",
"84c5f0c0d77aeb14",
"8e4f5c17e6c885b8"
"x": 254,
"y": 779,
"w": 752,
"h": 322
"id": "db194b3a981add30",
"type": "modbus-flex-sequencer",
"g": "1964653c8868349d",
"name": "模拟量",
"sequences": [
"name": "模拟量1",
"unitid": "4",
"fc": "FC4",
"address": "0",
"quantity": "2"
"server": "3ab6da8a17d3a981",
"showStatusActivities": false,
"showErrors": false,
"logIOActivities": false,
"useIOFile": false,
"ioFile": "",
"useIOForPayload": false,
"emptyMsgOnFail": false,
"keepMsgProperties": false,
"x": 570,
"y": 440,
"91406028333b4757",
"d6bd6820cc9c86c4"
"dea8d86c68bb5e34"
"id": "d6bd6820cc9c86c4",
"type": "modbus-response",
"registerShowMax": 20,
"x": 830,
"y": 460,
"id": "2d11710d8950e6b0",
"name": "数字量输入",
"sequences": [
"name": "数字量输入1",
"unitid": "2",
"fc": "FC4",
"address": "0",
"quantity": "2"
"useIOFile": false,
"ioFile": "",
"x": 590,
"y": 200,
"ca5832a1a8687599",
"4083025c0899d485"
"3dacf9589ea47ed6"
"id": "ca5832a1a8687599",
"x": 830,
"y": 220,
"id": "3dacf9589ea47ed6",
"name": "温湿度",
"sequences": [
"name": "温度",
"unitid": "3",
"fc": "FC4",
"address": "0",
"quantity": "2"
"useIOFile": false,
"ioFile": "",
"x": 570,
"y": 320,
"49c68e7312599925",
"baf7dab8bc12de02"
"db194b3a981add30"
"id": "baf7dab8bc12de02",
"x": 830,
"y": 340,
"id": "657b712d240c8b9e",
"type": "inject",
"props": [
"p": "payload"
"repeat": "0.5",
"crontab": "",
"once": false,
"onceDelay": "0.25",
"topic": "",
"payload": "",
"payloadType": "str",
"x": 350,
"y": 200,
"2d11710d8950e6b0"
"id": "4083025c0899d485",
"type": "function",
"name": "设置全局变量",
"func": "msg.payload.key1 = msg.payload[0]; // 添加新的属性并赋值\nmsg.payload.key2 = msg.payload[1];\n\nglobal.set(\"key1\", msg.payload.key1); // 设置全局变量\nglobal.set(\"key2\", msg.payload.key2);\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 820,
"y": 160,
"id": "49c68e7312599925",
"type": "function",
"name": "设置全局变量",
"func": "msg.payload.temperature = msg.payload[0]; // 添加新的属性并赋值\nmsg.payload.humidity = msg.payload[1];\n\nglobal.set(\"temperature\", msg.payload.temperature); // 设置全局变量\nglobal.set(\"humidity\", msg.payload.humidity);\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 820,
"y": 280,
"722bbb3ff5d8c3ab"
"id": "91406028333b4757",
"type": "function",
"name": "设置全局变量",
"func": "msg.payload.voltage1 = msg.payload[0]; // 添加新的属性并赋值\nmsg.payload.voltage2 = msg.payload[1];\n\nglobal.set(\"voltage1\", msg.payload.voltage1); // 设置全局变量\nglobal.set(\"voltage2\", msg.payload.voltage2);\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 820,
"y": 400,
"id": "0f9d16a881e6d926",
"type": "comment",
"name": "读取传感器数据",
"info": "",
"x": 360,
"y": 120,
"id": "84425a7eb012ce1e",
"type": "modbus-write",
"g": "3c4c8ee1c0e8b06f",
"name": "写寄存器",
"unitid": "2",
"dataType": "HoldingRegister",
"adr": "0",
"quantity": "1",
"x": 800,
"y": 640,
"id": "dea8d86c68bb5e34",
"type": "function",
"name": "FC3 2 0 [1]",
"func": "msg.payload = { \n 'fc': 3, \n 'unitid': 2, \n 'address': 0 , \n 'quantity': 1 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 430,
"y": 680,
"972d12e07fdac55a"
"id": "972d12e07fdac55a",
"type": "modbus-flex-getter",
"name": "50000",
"server": "244ca65087e1d0d0",
"useIOFile": false,
"ioFile": "",
"x": 610,
"y": 680,
"5e24e053f497b8d6",
"84425a7eb012ce1e"
"id": "5e24e053f497b8d6",
"x": 830,
"y": 720,
"id": "19514fe8f6cbd369",
"type": "comment",
"name": "控制风扇开关",
"info": "",
"x": 350,
"y": 560,
"id": "561d7e41803d66fe",
"type": "comment",
"name": "获取来自Modbus Server的值",
"info": "",
"x": 480,
"y": 640,
"id": "aed82866809e0eb3",
"type": "function",
"g": "b091717ec90e710f",
"name": "temperature",
"func": "msg.payload = { \n 'value': global.get(\"temperature\"), \n 'register': 'input', \n 'address': 0, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 630,
"y": 860,
"fa6698a7a0c342ef"
"id": "fa6698a7a0c342ef",
"type": "modbus-server",
"logEnabled": false,
"hostname": "0.0.0.0",
"serverPort": "50000",
"responseDelay": 100,
"delayUnit": "ms",
"coilsBufferSize": "10",
"holdingBufferSize": "10",
"inputBufferSize": "10",
"discreteBufferSize": "10",
"x": 900,
"y": 960,
"id": "6219c63f8289f41c",
"type": "function",
"name": "humidity",
"func": "msg.payload = { \n 'value': global.get(\"humidity\"), \n 'register': 'input', \n 'address': 1, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 900,
"fa6698a7a0c342ef"
"id": "2330626e4eac6a89",
"type": "function",
"name": "voltage1",
"func": "msg.payload = { \n 'value': global.get(\"voltage1\"), \n 'register': 'input', \n 'address': 2, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 940,
"fa6698a7a0c342ef"
"id": "381ebb1a749733e7",
"type": "function",
"name": "voltage2",
"func": "msg.payload = { \n 'value': global.get(\"voltage2\"), \n 'register': 'input', \n 'address': 3, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 980,
"fa6698a7a0c342ef"
"id": "4872de3d7499e5cb",
"type": "function",
"name": "key1",
"func": "msg.payload = { \n 'value': global.get(\"key1\"), \n 'register': 'input', \n 'address': 4, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 610,
"y": 1020,
"fa6698a7a0c342ef"
"id": "c4a7cc7ba8e9e048",
"type": "function",
"name": "key2",
"func": "msg.payload = { \n 'value': global.get(\"key2\"), \n 'register': 'input', \n 'address': 5, \n 'disableMsgOutput': 0 \n}; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 610,
"y": 1060,
"fa6698a7a0c342ef"
"id": "84c5f0c0d77aeb14",
"type": "comment",
"name": "数据上传至 Modbus Server",
"info": "",
"x": 390,
"y": 820,
"id": "8e4f5c17e6c885b8",
"type": "inject",
"props": [
"p": "payload"
"repeat": "1",
"crontab": "",
"once": false,
"topic": "",
"payload": "",
"x": 370,
"y": 960,
"aed82866809e0eb3",
"6219c63f8289f41c",
"2330626e4eac6a89",
"381ebb1a749733e7",
"4872de3d7499e5cb",
"c4a7cc7ba8e9e048"
"id": "722bbb3ff5d8c3ab",
"type": "debug",
"name": "debug 1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload.temperature",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1020,
"y": 280,
"id": "3ab6da8a17d3a981",
"type": "modbus-client",
"clienttype": "simpleser",
"bufferCommands": true,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": true,
"tcpHost": "127.0.0.1",
"tcpPort": "502",
"tcpType": "DEFAULT",
"serialPort": "/dev/ttySTM2",
"serialType": "RTU-BUFFERD",
"serialBaudrate": "9600",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "100",
"serialAsciiResponseStartDelimiter": "0x3A",
"unit_id": "1",
"commandDelay": "60",
"clientTimeout": "1000",
"reconnectOnTimeout": true,
"reconnectTimeout": "2000",
"parallelUnitIdsAllowed": true
"id": "244ca65087e1d0d0",
"clienttype": "tcp",
"tcpHost": "0.0.0.0",
"tcpPort": "50000",
"tcpType": "TCP-RTU-BUFFERED",
"serialPort": "/dev/ttyUSB",
"unit_id": "1",
"commandDelay": "1",
Another question is this:
Each piece of data takes up 4 bytes, am I setting something up wrong? I want to make them all consecutive.
As in the picture:
