How use dist folder in uibuilder
In order to use npm packages, I need to bundle my code with webpack and place it inside the dist folder. But uibuilder does not recognize the dist folder. what should I do?
The resource from “http://localhost:1890/dist/definemission.js” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
Loading failed for the <script> with source “http://localhost:1890/dist/definemission.js”.
Read the docs? :smiley:
The advanced tab lets you switch between src and dist.
