HTTP In node, how to get the URL itself
Hello, I set up several HTTP In nodes with different URLs, such as /check-state, /check-location, etc. Is there a variable to get this URL (ie /check-state or just check-state) so I can use it as a parameter in subsequent nodes? I know the alternative (which works) is to use URL parameters. Thank you.
It will be somewhere under msg.req - not near a computer to look for you
Thanks, will do some investigation starting there.
follow-up>>> req.url gave me the URL.
