I want to perform a HTTP POST request with form(?) data.
Function node:
msg.headers = {}
msg.method = "POST"
msg.url = "https://api.goslide.io/api/auth/login"
msg.payload = {"email": "email","password": "pass"}
msg.headers["content-type"] = "application/json"
msg.headers["X-Requested-With"] = "XMLHttpRequest"
return msg
API documentation states that headers should be:
Content-Type : application/json
X-Requested-With: XMLHttpRequest
The info for the http request node states:
To encode the request as form data, msg.headers["content-type"] should be set to application/x-www-form-urlencoded.
With application/json I get authorisation failed, with the application/x-www-form-urlencoded it failed and expects application/json
How can I post this with the correct header(s) ?
Andrei
2
A look in the API documentation confirms that the body of the POST request has to be JSON, like below to login and request a token
"email": "your@email.com",
"password": "yourpassword"
In such case the content-type should be application/JSON.
The reply I got when testing the API was:
"{"message":"Unauthorized"}"
which confirms that the POST request is OK, it is jus the server that is not authorizing.
I was wondering about that.
What is the application/x-www-form-urlencoded used for?
Andrei
4
In the case the body of the request will be like below, which is very similar to the query parameters of a GET request (key,values separated by &):
q=node+red&num=10
Got it. makes sense.
I will contact the folks behind the api.
Tried it via curl (should have done that earlier) and indeed same error.
