I am using "http request" nodes often in my flows and I have never had any problems.
Right now I am using an http request node to download two CSV files of ~ 2mb size.
When the execution of the flow reaches this node, the blue box is left marked and Node-RED crash without releasing any information.
Restarting Node-RED and deleting the node to put a new one, sometimes it works 1 time but then it keeps failing.
This problem arose after carrying about 3 hours working in the flow and that same node was behaving correctly until its failure.
Environment specifications:
- Node-RED version: v0.20.5
- Node.js version: v8.15.1
- Linux 3.10.0-693.11.1.el7.x86_64 x64 LE
- Docker image: nodered/node-red-docker
 Node-RED logs:
24/4/2019 14:33:5824 Apr 12:33:58 - [info] Node.js  version: v8.15.1
24/4/2019 14:33:5824 Apr 12:33:58 - [info] Linux 3.10.0-693.11.1.el7.x86_64 x64 LE
24/4/2019 14:33:5824 Apr 12:33:58 - [info] Loading palette nodes
24/4/2019 14:33:5924 Apr 12:33:59 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
24/4/2019 14:33:5924 Apr 12:33:59 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
24/4/2019 14:33:5924 Apr 12:33:59 - [info] Worldmap version 1.5.39
24/4/2019 14:33:59Installing %ccolor:black;font-weight:bold;%c and enabling features %cCLJS DevTools 0.9.10 %ccolor:black %ccolor:#0000ff :formatters color:#ccc :hints color:#ccc :async
24/4/2019 14:33:59BigML NodeRed-Core package
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Dashboard version 2.14.0 started at /ui
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Settings file  : /data/settings.js
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Context store  : 'default' [module=memory]
24/4/2019 14:34:0024 Apr 12:34:00 - [info] User directory : /data
24/4/2019 14:34:0024 Apr 12:34:00 - [warn] Projects disabled : editorTheme.projects.enabled=false
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Flows file     : /data/flows.json
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Server now running at http://127.0.0.1:1880/
24/4/2019 14:34:00
24/4/2019 14:34:00---------------------------------------------------------------------
24/4/2019 14:34:00Your flow credentials file is encrypted using a system-generated key.
24/4/2019 14:34:00
24/4/2019 14:34:00If the system-generated key is lost for any reason, your credentials
24/4/2019 14:34:00file will not be recoverable, you will have to delete it and re-enter
24/4/2019 14:34:00your credentials.
24/4/2019 14:34:00
24/4/2019 14:34:00You should set your own key using the 'credentialSecret' option in
24/4/2019 14:34:00your settings file. Node-RED will then re-encrypt your credentials
24/4/2019 14:34:00file using your chosen key the next time you deploy a change.
24/4/2019 14:34:00
24/4/2019 14:34:0024 Apr 12:34:00 - [info] Starting flows
24/4/2019 14:34:0024 Apr 12:34:00 - [info] [worldmap:Route map] started at /map
24/4/2019 14:34:0024 Apr 12:34:00 - [info] [inject:startPredict] crontab = 00 06 * * *
24/4/2019 14:34:0124 Apr 12:34:01 - [info] Started flows
24/4/2019 14:34:0124 Apr 12:34:01 - [info] [inject:hostStatus] repeat = 30000
24/4/2019 14:35:0024 Apr 12:35:00 - [info] Stopping modified nodes
24/4/2019 14:35:0024 Apr 12:35:00 - [info] Stopped modified nodes
24/4/2019 14:35:0024 Apr 12:35:00 - [info] Starting modified nodes
24/4/2019 14:35:0024 Apr 12:35:00 - [info] Started modified nodes
24/4/2019 14:36:00
24/4/2019 14:36:00
24/4/2019 14:36:00#
24/4/2019 14:36:00# Fatal error in , line 0
24/4/2019 14:36:00# API fatal error handler returned after process out of memory
24/4/2019 14:36:00#
24/4/2019 14:36:19Illegal instruction (core dumped)
24/4/2019 14:36:19npm ERR! code ELIFECYCLE
24/4/2019 14:36:19npm ERR! errno 132
24/4/2019 14:36:19npm ERR! node-red-docker@1.0.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"`
24/4/2019 14:36:19npm ERR! Exit status 132
24/4/2019 14:36:19npm ERR! Failed at the node-red-docker@1.0.0 start script.
24/4/2019 14:36:19npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
24/4/2019 14:36:20
24/4/2019 14:36:20npm ERR! A complete log of this run can be found in:
24/4/2019 14:36:20npm ERR!     /root/.npm/_logs/2019-04-24T12_36_19_853Z-debug.log
24/4/2019 14:36:202019-04-24T12:36:26.396857141Z
24/4/2019 14:36:26> node-red-docker@1.0.0 start /usr/src/node-red
24/4/2019 14:36:26> node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"
/root/.npm/_logs/2019-04-24T12_36_19_853Z-debug.log:
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli   '/usr/local/bin/npm',
1 verbose cli   'start',
1 verbose cli   '--',
1 verbose cli   '--userDir',
1 verbose cli   '/data' ]
2 info using npm@6.4.1
3 info using node@v8.15.1
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle node-red-docker@1.0.0~prestart: node-red-docker@1.0.0
6 info lifecycle node-red-docker@1.0.0~start: node-red-docker@1.0.0
7 verbose lifecycle node-red-docker@1.0.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle node-red-docker@1.0.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/usr/src/node-red/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
9 verbose lifecycle node-red-docker@1.0.0~start: CWD: /usr/src/node-red
10 silly lifecycle node-red-docker@1.0.0~start: Args: [ '-c',
10 silly lifecycle   'node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"' ]
11 silly lifecycle node-red-docker@1.0.0~start: Returned: code: 132  signal: null
12 info lifecycle node-red-docker@1.0.0~start: Failed to exec start script
13 verbose stack Error: node-red-docker@1.0.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"`
13 verbose stack Exit status 132
13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
13 verbose stack     at emitTwo (events.js:126:13)
13 verbose stack     at EventEmitter.emit (events.js:214:7)
13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack     at ChildProcess.emit (events.js:214:7)
13 verbose stack     at maybeClose (internal/child_process.js:915:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
14 verbose pkgid node-red-docker@1.0.0
15 verbose cwd /usr/src/node-red
16 verbose Linux 3.10.0-693.11.1.el7.x86_64
17 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "--" "--userDir" "/data"
18 verbose node v8.15.1
19 verbose npm  v6.4.1
20 error code ELIFECYCLE
21 error errno 132
22 error node-red-docker@1.0.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"`
22 error Exit status 132
23 error Failed at the node-red-docker@1.0.0 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 132, true ]
I have been searching the network, I have verified the cache, I have also used: increase-memory-limit from https://www.npmjs.com/package/increase-memory-limit but I have not achieved anything.
