Would anyone have a tip on how I can create an HTTP request with node red flow?
This is Python code that I can trying to figure out how to recreate with node-red. Its an http POST with form data.
import requests
url = "http://127.0.0.1:5000/read"
read_req = {"address": "12345:2",
"object_type": "analogValue",
"object_instance": "302"}
print(requests.post(url, read_req).text)
Just trying to use the http request block, still learning node-red
But in node red it doesnt seem like there is an easy button for an http post for form data. Would anyone have any tips? Any tips with a javascript function would be greatly appreciated if I need to go to that extent.
Hi @bbartling
Add a Function node in front of the HTTP Request node with the following:
msg.payload = {
Does this look right?
msg.headers = {
"Content-Type": "application/json"
msg.payload = {
This is what I have so far thanks for the tips, does it look right?
For some reason in the console I am getting a
In Python requests ill get this if the keys arent named correctly
"address":
"object_type"
"object_instance"
You currently have the HTTP Request node configured to return a parsed JSON object. The error you're getting suggests the response to the HTTP Request isn't parsable JSON. Change the Request node configuration to return a String and see what you get.
