Httprequest node - help
That is because speed-test is not installed. The npm command says Show me all the places agent-base is used and what version it is. If you look at the earlier post it had
npm list agent-base
node-red-project@0.0.1 /home/me/.node-red
├─┬ node-red-contrib-speed-test@0.1.2
│ └─┬ speedtest-net@1.6.2
│   ├─┬ http-proxy-agent@2.1.0
│   │ └── agent-base@4.3.0
│   └─┬ https-proxy-agent@3.0.1
└─┬ node-red-contrib-tts-ultimate@2.0.5
  ├─┬ @google-cloud/text-to-speech@4.2.2
  │ └─┬ google-gax@3.6.1
  │   └─┬ google-auth-library@8.9.0
  │     └─┬ gaxios@5.1.3
  │       └─┬ https-proxy-agent@5.0.1
  │         └── agent-base@6.0.2 deduped
  └─┬ microsoft-cognitiveservices-speech-sdk@1.29.0
    ├── agent-base@6.0.2
    └─┬ https-proxy-agent@4.0.0
      └── agent-base@5.1.1
So you can see that agent-base 4.3.0 is used by http-proxy-agent which is used by speedtest.net which is used by node-red-contrib-speed-test.
Now you no longer have speed-test installed the early version of agent base is not used.
I am sorry @Colin, but.....
This screen shot kinda says otherwise.
You still don't see the problem, even though I have pointed it out several times. There are two contrib nodes. node-red-contrib-speed-test and node-red-contrib-speedtest. The former was the one causing the problem. Now you are using the latter.
(that's why the TRYING is still in my name.)
Colin,
I am really sorry.
Back in post 3 I can see the TWO lists of the node.
(Well, not exactly. One is hidden in the node-red... Oh, sorry. That's another layer of confusion my end.)
I seem fixated on that node.
Hang on, I'll try to see it again.
Ok, your post 6.....
Yeah, with you - kind of.
So WHO is the speedtest node shown above?
Oh! it is speedtest (no hyphen).... Ok. With you now.
Wow.... I really do seem to need a new brain.
