This is my docker compose file
version: "3"
services:
nodered:
container_name: nodered
image: nodered/node-red:latest
restart: always
environment:
- TZ=Asia/Kolkata
ports:
- "1880:1880"
networks:
- public
volumes:
- "/mnt/external/nr-personal:/data"
volumes:
nr-personal:
networks:
public:
Logs:
npm ERR! Exit status 1
npm ERR! Failed at the node-red-docker@2.1.4 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
> node-red-docker@2.1.4 start /usr/src/node-red
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
internal/fs/utils.js:332
throw err;
Error: EACCES: permission denied, copyfile '/usr/src/node-red/node_modules/node-red/settings.js' -> '/data/settings.js'
at Object.copyFileSync (fs.js:2061:3)
at copyFile (/usr/src/node-red/node_modules/fs-extra/lib/copy-sync/copy-sync.js:70:6)
at onFile (/usr/src/node-red/node_modules/fs-extra/lib/copy-sync/copy-sync.js:56:25)
at getStats (/usr/src/node-red/node_modules/fs-extra/lib/copy-sync/copy-sync.js:48:44)
at handleFilterAndCopy (/usr/src/node-red/node_modules/fs-extra/lib/copy-sync/copy-sync.js:33:10)
at Object.copySync (/usr/src/node-red/node_modules/fs-extra/lib/copy-sync/copy-sync.js:26:10)
at Object.<anonymous> (/usr/src/node-red/node_modules/node-red/red.js:125:20)
at Module._compile (internal/modules/cjs/loader.js:1085:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
at Module.load (internal/modules/cjs/loader.js:950:32) {
errno: -13,
syscall: 'copyfile',
code: 'EACCES',
path: '/usr/src/node-red/node_modules/node-red/settings.js',
dest: '/data/settings.js'
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-docker@2.1.4 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"`
throw err;
errno: -13,
code: 'EACCES',
npm ERR! errno 1
throw err;
errno: -13,
code: 'EACCES',
npm ERR! errno 1
