I can't format a date in JSONATA
Hey,
I don't understand why my JSONATA line doesn't work in my “Converter” node, about the msg.filename.
If someone can take a look :
[{"id":"99e019d5.6f0748","type":"tab","label":"Payrolls","disabled":false,"info":"# Pay slips\n\n---\n\n## Context\n\nThis flow aims to **convert U.S. payrolls** into the format accepted by Akuiteo, the Braincube ERP.\n\nThe goal of this program is to **lighten the workload for U.S. accountants** that actually convert this files manually before import them into Akuiteo.\n\n---\n\n*Pierre Demay*"},{"id":"b6f48a9686873260","type":"switch","z":"99e019d5.6f0748","name":"Check Totals","property":"payload[\"Account Number\"]","propertyType":"msg","rules":[{"t":"neq","v":"Totals","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":490,"y":440,"wires":[["70df4b713dbde058"],["83a97711d2124147"]]},{"id":"c61fccdafaa0d73f","type":"file","z":"99e019d5.6f0748","name":"Converted payrolls","filename":"/Users/pierre.demay/Documents/Payrolls/converted_payroll.csv","filenameType":"str","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":1250,"y":500,"wires":[[]]},{"id":"39c7f94430e9bc18","type":"debug","z":"99e019d5.6f0748","name":"In CSV format","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1380,"y":440,"wires":[]},{"id":"01e93f44240ae48d","type":"debug","z":"99e019d5.6f0748","name":"After convert","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":970,"y":340,"wires":[]},{"id":"70df4b713dbde058","type":"change","z":"99e019d5.6f0748","name":"Converter","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.{\t    \"EC_NUMERO\": $moment($.Date, \"MM/DD/YY\").format(\"[BCUSA]YY[PR]MMDDYYYY\"),\t    \"EC_DATE\": $moment($.Date, \"MM/DD/YY\").format(\"DD/MM/YYYY\"),\t    \"EC_CODE_JOURNAL\": \"GS\",\t    \"EC_EXERCICE\": 24,\t    \"LI_COMPTE\": $.\"Account Number\",\t    \"LI_LIBELLE\": $.\"Account Name\",\t    \"LI_DEBIT\": ($.Debit or $.Debit = 0 or $.Debit = \"0\") ? $number($.Debit) : \"\",\t    \"LI_CREDIT\": ($.Credit or $.Credit = 0 or $.Credit = \"0\") ? $number($.Credit) : \"\",\t    \"LI_DEVISE\": \"USD\",\t    \"LI_PIECE\": \"\",\t    \"LI_AFFAIRE\": \"\"\t}","tot":"jsonata"},{"t":"set","p":"filename","pt":"msg","to":"$moment(msg.payload.Date, \"MM/DD/YY\").format(\"MM.DD.YY\") & \" Payroll Upload.csv\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":400,"wires":[["3f75f2b15d06a79c"]]},{"id":"6e7ff3542689d007","type":"csv","z":"99e019d5.6f0748","name":"","sep":",","hdrin":"","hdrout":"all","multi":"mult","ret":"\\n","temp":"EC_NUMERO,EC_DATE,EC_CODE_JOURNAL,EC_EXERCICE,LI_COMPTE,LI_LIBELLE,LI_DEBIT,LI_CREDIT,LI_DEVISE,LI_PIECE,LI_AFFAIRE","skip":"0","strings":true,"include_empty_strings":true,"include_null_values":true,"x":1210,"y":440,"wires":[["39c7f94430e9bc18"]]},{"id":"fd06513d329c277d","type":"join","z":"99e019d5.6f0748","name":"","mode":"auto","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":850,"y":440,"wires":[["9357b06e56fe6e74","06bef7c14f1874c2"]]},{"id":"9357b06e56fe6e74","type":"debug","z":"99e019d5.6f0748","name":"After join","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1000,"y":500,"wires":[]},{"id":"3f75f2b15d06a79c","type":"function","z":"99e019d5.6f0748","name":"Project finder","func":"if (msg.payload.LI_COMPTE.toString().substr(0, 1) == \"1\") {\n    msg.payload.LI_AFFAIRE = \"B000030\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 1) == \"2\") {\n    msg.payload.LI_AFFAIRE = \"B000030\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6500\") {\n    msg.payload.LI_AFFAIRE = \"B000031\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6501\") {\n    msg.payload.LI_AFFAIRE = \"B000040\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6510\") {\n    msg.payload.LI_AFFAIRE = \"B000024\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6515\") {\n    msg.payload.LI_AFFAIRE = \"B000025\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6520\") {\n    msg.payload.LI_AFFAIRE = \"B000026\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6525\") {\n    msg.payload.LI_AFFAIRE = \"???\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6530\") {\n    msg.payload.LI_AFFAIRE = \"B000029\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6600\") {\n    msg.payload.LI_AFFAIRE = \"B000031\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6603\") {\n    msg.payload.LI_AFFAIRE = \"B000031\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6608\") {\n    msg.payload.LI_AFFAIRE = \"B000029\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6609\") {\n    msg.payload.LI_AFFAIRE = \"B000040\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6610\") {\n    msg.payload.LI_AFFAIRE = \"B000024\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6615\") {\n    msg.payload.LI_AFFAIRE = \"B000025\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6620\") {\n    msg.payload.LI_AFFAIRE = \"B000026\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6625\") {\n    msg.payload.LI_AFFAIRE = \"B000040\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6700\") {\n    msg.payload.LI_AFFAIRE = \"B000031\";\n    return msg;\n} else if (msg.payload.LI_COMPTE.toString().substr(0, 4) == \"6715\") {\n    msg.payload.LI_AFFAIRE = \"B000025\";\n    return msg;\n}","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":790,"y":340,"wires":[["fd06513d329c277d","01e93f44240ae48d","59504208defd4046"]]},{"id":"83a97711d2124147","type":"change","z":"99e019d5.6f0748","name":"Mark unwanted","rules":[{"t":"set","p":"payload.unwanted","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":480,"wires":[["fd06513d329c277d"]]},{"id":"06bef7c14f1874c2","type":"function","z":"99e019d5.6f0748","name":"Remove unwanted","func":"msg.payload = msg.payload.filter(row => !row.unwanted)\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1030,"y":440,"wires":[["6e7ff3542689d007"]]},{"id":"367231415fcc33e2","type":"split","z":"99e019d5.6f0748","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":330,"y":440,"wires":[["b6f48a9686873260","3da73b9bc9f311bf"]]},{"id":"3bcc7f4a6bac6b1e","type":"inject","z":"99e019d5.6f0748","name":"Initialization","props":[],"repeat":"","crontab":"","once":false,"onceDelay":"1","topic":"","x":170,"y":320,"wires":[["4963d8f88af763f7"]]},{"id":"4963d8f88af763f7","type":"file in","z":"99e019d5.6f0748","name":"Payrolls","filename":"/Users/pierre.demay/Documents/Payrolls/payroll.csv","filenameType":"str","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":340,"y":320,"wires":[["5aee9603e5fc56ef"]]},{"id":"5aee9603e5fc56ef","type":"csv","z":"99e019d5.6f0748","name":"","sep":",","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"2","strings":true,"include_empty_strings":"","include_null_values":"","x":330,"y":380,"wires":[["367231415fcc33e2"]]},{"id":"3da73b9bc9f311bf","type":"debug","z":"99e019d5.6f0748","name":"Base data","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":480,"y":500,"wires":[]},{"id":"01b8721a3bd9f145","type":"inject","z":"99e019d5.6f0748","name":"Initialization","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"Account Number\":6620500,\"Account Name\":\"Payroll Expenses:Social Charges:Social Charges-Tech\",\"Employee\":\"Yamada, Kuranosuke\",\"Credit\":4.55,\"Date\":\"4/15/24\"},{\"Account Number\":6620500,\"Account Name\":\"Payroll Expenses:Social Charges:Social Charges-Tech\",\"Employee\":\"Yamada, Kuranosuke\",\"Debit\":402.34,\"Date\":\"4/15/24\"},{\"Account Number\":662550,\"Account Name\":\"Payroll Expenses:Social Charges:Support\",\"Employee\":\"Cojo, Ekaterina\",\"Credit\":16.51,\"Date\":\"4/15/24\"},{\"Account Number\":662550,\"Account Name\":\"Payroll Expenses:Social Charges:Support\",\"Employee\":\"Cojo, Ekaterina\",\"Debit\":384.47,\"Date\":\"4/15/24\"},{\"Account Number\":6700045,\"Account Name\":\"Payroll Expenses:BONUS: Hannan, Alicia\",\"Employee\":\"Hannan, Alicia C\",\"Debit\":1000,\"Date\":\"4/15/24\"},{\"Account Number\":\"Totals\",\"Debit\":223208.73,\"Credit\":223208.73}]","payloadType":"json","x":170,"y":440,"wires":[["367231415fcc33e2"]]},{"id":"59504208defd4046","type":"debug","z":"99e019d5.6f0748","name":"Filename","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"filename","targetType":"msg","statusVal":"","statusType":"auto","x":960,"y":280,"wires":[]}]
Please do us a favour and insert a couple of debug nodes
So that we can see the data going in to "Converter" and the data emerging from it.
Post the data as text not a picture.
Explain in what way the data out fails to meet your requirements.
I am prepared to investigate a flow like this
But not a flow like this
@pierredemay this is good advise from JBudd. Please try to focus your issues to a small reproducible demo.
@jbudd That is EXACTLY what i did to figure out what was happening
