I don't install node-red-contrib-rtsp-client
Continuing the discussion from How to display live video to the node red dashboard and have the ability to simply turn it on and turn it off with either a slide switch or "On" "Off" push buttons:
I couldn't install this colleague's contribution?
Any suggestion ?
The post you link to includes the instructions for how to install it. You have not run the command given in the instructions.
@allacmc,
My node-red-contrib-rtsp-client node is only available on github and not on npm, since I had not enough free time to finalize the last pieces of it.
Bart
Is it possible to make this wonderful contribution available on npm?
I'm a little lost on how to get this code from git hub and install it on node red
I know you must be very busy and this node is a voluntary contribution.
But I would be extremely grateful if you could please.
It will solve a big problem of mine here.
No, I almost have no free time left anymore for Node-RED. When I publish it on npm, people start using it, and expect me to solve all their issues with it...
And I am by far an ffmpeg expert. As a result I need to forward all my questions to our guru @kevinGodell, who is also very busy.
If I remember correctly I haven't found a way to extract separate jpegs from it. That was a basic requirement for my own home automation to develop this node, but I failed to do that. Cpu usage became very high.
So this node became useless for me...
You can install the node from my Github repository like this:
  1. Install git
  2. Navigate to your .node-red folder
  3. Execute npm install bartbutenaers/node-red-contrib-rtsp-client in this folder
