Hi mates, when I start NR it shows me:
your credentials.
I've neve set credentialSecret and I don't want to do it, my system is safe and not exposed to anyone else, I don't want to encript nothing and avoid any kind of problem cloning/importing to a new system my flow, I don't want to risk to loose the ton of hours I've spent on NR building my flow, I just want to sleep fine at night
Actually my flow is not encripted, I can open it with an editor and see all data, so I don't know why NR tells me it's encrypted with a system key it generated, can you please clear me more about that?
Should I leave it as now? (still in defaut as installed, about that setting).
Thank you
