"id": "6413a75bc26624d5",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "6f4019ff5839f3ce",
"type": "http response",
"z": "6413a75bc26624d5",
"statusCode": "",
"headers": {},
"x": 670,
"y": 160,
"id": "5a450b35838cf1c0",
"type": "http in",
"url": "/time-form",
"method": "post",
"upload": false,
"swaggerDoc": "",
"x": 380,
"y": 220,
"6f4019ff5839f3ce",
"8e6f24219e6d5628"
"id": "7c8013576233982a",
"type": "ui_template",
"group": "2005ea10b222ccc9",
"name": "Mon-to-Fri_On-Timer",
"order": 3,
"width": 0,
"height": 0,
"format": "<html>\n\n<head>\n <title>Time Form</title>\n <script src=\"https://code.jquery.com/jquery-3.6.0.min.js\"></script>\n <script>\n $(function() {\n $('form').submit(function(event) {\n event.preventDefault();\n $.ajax({\n url: '/time-form',\n type: 'POST',\n data: $('form').serialize(),\n success: function(result) {\n $('#result').text(result);\n }\n });\n });\n });\n </script>\n\n</head>\n\n<body>\n <h1>Enter a Time Value</h1>\n <form>\n <label for=\"time-input\">Time:</label>\n <input type=\"time\" id=\"time\" name=\"time\" value=\"{{payload.time}}\">\n <button type=\"submit\">Submit</button>\n </form>\n <div id=\"result\"></div>\n</body>\n\n\n\n</html>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 460,
"y": 160,
"6f4019ff5839f3ce"
"id": "ea45db27910ba680",
"type": "function",
"name": "function 51",
"func": "// Convert hexadecimal string to decimal number\nvar in_value = msg.payload;\n//var ura = in_value * 100\nvar ura = in_value * 1\nvar hex = msg.payload\nvar decimal = parseInt(ura, 16);\n\n// Create new message with decimal number\nmsg.payload = decimal;\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 730,
"y": 220,
"74b534acf8298ce0"
"id": "8e6f24219e6d5628",
"type": "function",
"name": "function 52",
"func": "var timeValue = msg.payload.time;\n\n// Check that the time value is not empty\nif (!timeValue) {\n msg.payload = \"Error: Time value is empty\";\n return msg;\n}\n\nvar timeParts = timeValue.split(\":\");\nvar hours = parseInt(timeParts[0]);\nvar minutes = parseInt(timeParts[1]);\n\n//var decimalValue = hours + minutes / 60;\nvar decimalValue = hours *100 + minutes ;\nmsg.payload = decimalValue;\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 570,
"y": 220,
"ea45db27910ba680"
"id": "1ced31a1d5dcee6a",
"type": "comment",
"name": "nedelujoč form za time",
"info": "",
"x": 580,
"y": 120,
"id": "6b0f3fa0b1cd2f44",
"type": "http in",
"method": "get",
"upload": false,
"swaggerDoc": "",
"x": 240,
"y": 160,
"7c8013576233982a"
"id": "74b534acf8298ce0",
"type": "debug",
"name": "debug 21",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 900,
"y": 220,
"id": "2005ea10b222ccc9",
"type": "ui_group",
"name": "test",
"tab": "e2e04d88d4584015",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "e2e04d88d4584015",
"type": "ui_tab",
"name": "test timer",
"icon": "dashboard",
"order": 9,
"disabled": false,
"hidden": false
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
You will also want to share some more details about what you are trying to achieve and what you've tried so far.
Take a look at the cookbook entry Create an HTTP Endpoint and see where you can go from there.
Also please explain what you are trying to do.
I fixed your code but in order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
