iEM3255 no connect to 2 slave power meter
Hello everyone
i have a problem integrated 2 unit power meter Schneider iEM3255 with node-red.
node-red can only read 1 device power meter.
i have a trial with wiring parrarel not sloved.
Has anyone here experienced the same thing? if so, how do you communicate between node-red and many slave ID modbus RTUs?
Welcome to forum @Ibnu
What node are you using to communicate with the devices? Probably node-red-contrib-something
i use node modbus read, fungtion and dasboard
There are multiple modbus nodes. Is it node-red-contrib-modbus or one of the others?
Yes it'is node-red-contrib-modbus "modbus read"
I try add delay time but not solved
Node-Red only read 1 device Slave ID
Device 1 slave ID 1
Device 2 slave ID 10
Select the two modbus nodes and export them here (Ctrl+E) and paste the flow here. When pasting use the </> button at the top of the forum entry window.
        "id": "161156e41157308c",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "212a073c4ea87f4f",
        "type": "modbus-read",
        "z": "161156e41157308c",
        "d": true,
        "name": "EM3255_Pipe_Line_A",
        "topic": "Avg Voltage (Single Phase)",
        "showStatusActivities": false,
        "logIOActivities": false,
        "showErrors": false,
        "unitid": "1",
        "dataType": "HoldingRegister",
        "adr": "3027",
        "quantity": "2",
        "rate": "4",
        "rateUnit": "s",
        "delayOnStart": false,
        "startDelayTime": "1",
        "server": "1b9e46852f0b832b",
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "x": 160,
        "y": 240,
                "2e574f173d7517b5"
        "id": "ef7a2fd32b34c36f",
        "type": "comment",
        "name": "Pipe Line A (Avg Voltage) single phase",
        "info": "",
        "x": 190,
        "y": 180,
        "id": "d1de58b843c23d6b",
        "type": "ui_gauge",
        "group": "0b9a7866b342a438",
        "order": 1,
        "width": 6,
        "height": 5,
        "gtype": "gage",
        "title": "AVG Voltage Phase-N",
        "label": "V",
        "format": "{{value}}",
        "min": 0,
        "max": "450",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 680,
        "y": 240,
        "id": "2e574f173d7517b5",
        "type": "function",
        "name": "int to float",
        "func": "/* Converts from an number, string, buffer or array representing an IEEE-754 value\n to a javascript float.\n The following may be given in msg.payload:\n A string representing a number, which may be hex or binary\n examples, \"1735\" \"0x02045789\" 0b01000000010010010000111111011011\n An integer value\n A two element array or buffer of 16 bit values, less significant byte first.\n A four element array or buffer of 8 bit values, most significant byte first.\n Source: https://flows.nodered.org/flow/359ead34237b7ab6ec0465ee85a34b62\n */\n // first make a number from the given payload if necessary\n let intValue;\n if (typeof msg.payload === \"number\") \n{\n intValue = msg.payload;\n } else if (typeof msg.payload === \"string\") {\n intValue = Number(msg.payload);\n } else if (msg.payload.length == 2) {\n // two int array or buffer\n intValue = (msg.payload[0] << 16) + msg.payload[1];\n } else if (msg.payload.length == 4) {\n // four byte array or buffer\n intValue = (((((msg.payload[0] << 8) + msg.payload[1]) << 8) + msg.payload[2]) <<\n 8) + msg.payload[3];\n } else {\n node.warn(\"Unrecognised payload type or length\");\n } \n msg.payload = Int2Float32(intValue);\n msg.payload = msg.payload.toFixed(1);\n return msg;\n function Int2Float32(bytes) {\n var sign = (bytes & 0x80000000) ? -1 : 1;\n var exponent = ((bytes >> 23) & 0xFF) - 127;\n var significand = (bytes & ~(-1 << 23));\n if (exponent == 128)\n return sign * ((significand) ? Number.NaN : Number.POSITIVE_INFINITY);\n if (exponent == -127) {\n if (significand === 0) return sign * 0.0;\n exponent = -126;\n significand /= (1 << 22);\n } else significand = (significand | (1 << 23)) / (1 << 23);\n return sign * significand * Math.pow(2, exponent);\n }",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 420,
        "y": 240,
                "d1de58b843c23d6b",
                "c1e27af7855e0664",
                "abb706727c9fc49c",
                "d9ac29a133345ea1"
        "id": "c1e27af7855e0664",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 660,
        "y": 140,
        "id": "abb706727c9fc49c",
        "type": "ui_text",
        "group": "0691c57e3688a701",
        "order": 1,
        "width": 6,
        "height": 1,
        "label": "Voltage Average Phase-N",
        "format": "{{msg.payload}}V",
        "layout": "row-spread",
        "className": "",
        "x": 690,
        "y": 300,
        "id": "d9ac29a133345ea1",
        "type": "ui_chart",
        "group": "51c1c643236ddf56",
        "order": 1,
        "width": 7,
        "height": 5,
        "label": "Grafik Avg Voltage Phase-N",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "450",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d93030",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 700,
        "y": 360,
        "id": "7fc769ac402cd712",
        "d": true,
        "name": "EM3255_Pipe_Line_B",
        "unitid": "10",
        "adr": "3027",
        "quantity": "2",
        "rate": "4",
        "rateUnit": "s",
        "startDelayTime": "2",
        "server": "255c14ab516089b5",
        "useIOFile": false,
        "ioFile": "",
        "x": 1000,
        "y": 240,
                "45c8b97784b9077b"
        "id": "68e7d1eb2e46eb3a",
        "type": "comment",
        "name": "Pipe Line B(Avg Voltage) single phase",
        "info": "",
        "x": 1030,
        "y": 180,
        "id": "0e1f01e1f6e59c2a",
        "type": "ui_gauge",
        "group": "b4c553cf349b9998",
        "order": 1,
        "width": 6,
        "height": 5,
        "gtype": "gage",
        "label": "V",
        "min": 0,
        "max": "450",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 1520,
        "y": 240,
        "id": "45c8b97784b9077b",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1260,
        "y": 240,
                "0e1f01e1f6e59c2a",
                "0e2724d03b6cc6a7",
                "22f930d2b84a0dec",
                "3f05da2509d88ef8"
        "id": "0e2724d03b6cc6a7",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": true,
        "tostatus": true,
        "x": 1500,
        "y": 140,
        "id": "22f930d2b84a0dec",
        "type": "ui_text",
        "group": "bc0105fd16829d98",
        "order": 1,
        "width": 6,
        "height": 1,
        "className": "",
        "x": 1530,
        "y": 300,
        "id": "3f05da2509d88ef8",
        "type": "ui_chart",
        "group": "db7c4fac4d4ec86a",
        "order": 1,
        "width": 7,
        "height": 6,
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "450",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d93030",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 1540,
        "y": 360,
        "id": "1b9e46852f0b832b",
        "type": "modbus-client",
        "name": "panel Line A",
        "clienttype": "serial",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "tcpHost": "127.0.0.1",
        "tcpPort": "502",
        "tcpType": "DEFAULT",
        "serialPort": "COM3",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": "9600",
        "serialDatabits": "8",
        "serialStopbits": "1",
        "serialParity": "even",
        "serialConnectionDelay": "100",
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": "1",
        "commandDelay": "1",
        "clientTimeout": "1000",
        "reconnectOnTimeout": true,
        "reconnectTimeout": "2000",
        "parallelUnitIdsAllowed": false
        "id": "0b9a7866b342a438",
        "type": "ui_group",
        "name": "Pipe Line A - Gauge ",
        "tab": "df1815b2eb054693",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "id": "0691c57e3688a701",
        "type": "ui_group",
        "name": "Pipe Line A - Summery ",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "id": "51c1c643236ddf56",
        "type": "ui_group",
        "name": "Pipe Line A - Grafik ",
        "order": 3,
        "disp": true,
        "width": 21,
        "collapse": true,
        "className": ""
        "id": "255c14ab516089b5",
        "name": "Panel Line B",
        "stateLogEnabled": true,
        "tcpPort": "502",
        "serialType": "RTU",
        "serialConnectionDelay": "2000",
        "unit_id": "10",
        "clientTimeout": "2000",
        "parallelUnitIdsAllowed": true
        "id": "b4c553cf349b9998",
        "type": "ui_group",
        "name": "Line B - Gauge ",
        "tab": "13288f18d8e4455a",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "id": "bc0105fd16829d98",
        "type": "ui_group",
        "name": "Pipe Line B - Summery ",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "id": "db7c4fac4d4ec86a",
        "type": "ui_group",
        "name": "Pipe Line B - Grafik ",
        "order": 3,
        "disp": true,
        "width": 21,
        "collapse": true,
        "className": ""
        "id": "df1815b2eb054693",
        "type": "ui_tab",
        "name": "PGAS Solution - Manufaktur Pipa PE Kwh Online (Pipe Line A)",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
        "id": "13288f18d8e4455a",
        "type": "ui_tab",
        "name": "PGAS Solution - Manufaktur Pipa PE Kwh Online (Line B)",
        "disabled": false,
        "hidden": false
oke i sent the clipboard
I asked for just the modbus nodes, not the whole flow, but I managed to see the problem. You have configured two server nodes (Panel line A and Panel line B) both trying to connect to the same serial port. You should have just one (make sure you delete the other one in the Menu > Configuration Nodes). Use the unit id in the read node to specify the device.
oke, but i try problem.
Device 1 Slave ID 1
Device 2 Slave ID 10
Modbus read Unit ID 1 (device 1) Server Pipe line A (unitID 10)
Modbus read Unit ID 10 (device 2) Server Pipe line A (unitID 10)
If you specify a unit id in the read node then the id in the server node is not used.
Is it working now?
I suggest calling the server node COM3 or something like that.
oke thanks you this is work now, i have control and data Power meter. but now problem is maksimum 8 node only.
whereas I need more nodes to display
I don't understand what you mean.
now I can communicate from node-red to 2 devices.
but currently only able to display 8 addresses. whereas I need more than 8 addresses
What do you mean by "address"
[Edit] and what is stopping you having more than eight of them?
