Hello i m want a simple if else sircet but instad of switches with buttons
so i select number 2 so Button 2 is true than thats saved for 5 second and when in this time a aktivations switch is pressed its true. but im not sure how to do this.
Hi @LostiLama
I am trying to understand what you mean, but can't.
What are the inputs - to be clear?
Node-red buttons or physical buttons via GPIO?
How many buttons?
Idea:
Although I believe time is also in the formula, try to draw a table of what you want to happen.
I can't show an example just now as formatting text is not allowed here.
I'll go away and make a picture and post it soon.
Grey = off
Green = on
yellow = don't care
1,2,3 inputs.
0 output.
This is a bit of code I made.
I don't really know what you want, but it does what I think you mean.
Press either of the inject nodes.
Press the other one within 5 seconds and you get an output.
If you wait more than 5 seconds, nothing happens.
Not perfect - I'm sure - and you need a foreign node:
node-red-contrib-queue-gate
[{"id":"435f958cf7838596","type":"trigger","z":"65c9b63cb09879a0","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":2550,"wires":[["d438eb4f1721d421"]]},{"id":"70fbcc90902efe7c","type":"inject","z":"65c9b63cb09879a0","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"A","payloadType":"str","x":280,"y":2550,"wires":[["435f958cf7838596","5a0977f7980f71c5","c211e18e54e5ffd7"]]},{"id":"12e5a75dfcd214da","type":"inject","z":"65c9b63cb09879a0","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"B","payloadType":"str","x":280,"y":2690,"wires":[["192d5ee3605f0aeb","e41b5aa7c73cccb8","a06e461907a508b7"]]},{"id":"192d5ee3605f0aeb","type":"trigger","z":"65c9b63cb09879a0","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":2690,"wires":[["c03615454637527a"]]},{"id":"5a0977f7980f71c5","type":"q-gate","z":"65c9b63cb09879a0","name":"","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"1","keepNewest":false,"qToggle":false,"persist":false,"storeName":"memory","x":610,"y":2490,"wires":[["c8fb069fb3e702eb"]]},{"id":"e41b5aa7c73cccb8","type":"q-gate","z":"65c9b63cb09879a0","name":"","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"1","keepNewest":false,"qToggle":false,"persist":false,"storeName":"memory","x":610,"y":2640,"wires":[["c8fb069fb3e702eb"]]},{"id":"d438eb4f1721d421","type":"change","z":"65c9b63cb09879a0","name":"Reset","rules":[{"t":"set","p":"payload","pt":"msg","to":"reset","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":2550,"wires":[["5a0977f7980f71c5","e41b5aa7c73cccb8"]]},{"id":"c211e18e54e5ffd7","type":"change","z":"65c9b63cb09879a0","name":"Trigger","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":2590,"wires":[["e41b5aa7c73cccb8"]]},{"id":"c03615454637527a","type":"change","z":"65c9b63cb09879a0","name":"Reset","rules":[{"t":"set","p":"payload","pt":"msg","to":"reset","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":2690,"wires":[["e41b5aa7c73cccb8","5a0977f7980f71c5"]]},{"id":"a06e461907a508b7","type":"change","z":"65c9b63cb09879a0","name":"Trigger","rules":[{"t":"set","p":"payload","pt":"msg","to":"trigger","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":2730,"wires":[["5a0977f7980f71c5"]]},{"id":"c8fb069fb3e702eb","type":"debug","z":"65c9b63cb09879a0","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":830,"y":2600,"wires":[]}]
Hope that helps.
Je this is the right Thing i needed Thanks
If you mean the code, it may be better to mark that post as the solution.
