Hello! I would like to test a feature that if no payload is received for 10 seconds, then .... code
(so if nothing comes from the mqtt in flow)
How to do this? (sorry, I still don't speak English)
Use a trigger node. The node has to be triggered once and you can specify that no message is sent at start. Then specify that a message is sent after 10 seconds. Switch on the option that the time is prolonged with each new message. Specify a message you want to send after the 10s. The result is that the message is sent when no message arrives within 10s.
I am a very beginner, could you give an example of a flow?
"id": "cabdb88e34d8c7a6",
"type": "mqtt in",
"z": "4735369af5996aeb",
"topic": "",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 370,
"y": 1300,
"29f08731b067e931"
"id": "29f08731b067e931",
"type": "trigger",
"op1": "",
"op2": "true",
"op1type": "nul",
"op2type": "bool",
"duration": "10",
"extend": true,
"overrideDelay": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 530,
"y": 1300,
