How to return message from a payload with boolean true value, but only if it is equal to what I set?
Would you expand you issue a bit please
How does MQTT fit in?
You should be able to use a switch node to test the value and then a change to set the value you want.
I managed to do it, but using several nodes, How would I do it using only the function node?
My program:
[{"id":"f9095345dc0c2946","type":"switch","z":"6b0282876aa2ecc3","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Liga","vt":"str"},{"t":"eq","v":"Desliga","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":160,"wires":[["ecd87482388e507e"],["57195910e1cca66b"]]},{"id":"b323ec2241fbfad9","type":"mqtt in","z":"6b0282876aa2ecc3","name":"","topic":"PISTAO","qos":"2","datatype":"auto","broker":"c6a90f85a98db3a6","nl":false,"rap":true,"rh":0,"inputs":0,"x":230,"y":160,"wires":[["f9095345dc0c2946"]]},{"id":"57195910e1cca66b","type":"convert","z":"6b0282876aa2ecc3","name":"","convertTo":"boolean (0/1)","x":530,"y":180,"wires":[["baf7742df2534949"]]},{"id":"ecd87482388e507e","type":"change","z":"6b0282876aa2ecc3","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":100,"wires":[["baf7742df2534949"]]},{"id":"baf7742df2534949","type":"s7 out","z":"6b0282876aa2ecc3","endpoint":"936469fb997a5f75","variable":"PISTAO","name":"","x":880,"y":160,"wires":[ ]},{"id":"c6a90f85a98db3a6","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"936469fb997a5f75","type":"s7 endpoint","transport":"iso-on-tcp","address":"192.168.0.101","port":"102","rack":"0","slot":"2","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","busaddr":"2","cycletime":"1000","timeout":"2000","name":"","vartable":[{"addr":"M0.0","name":"Start"},{"addr":"M0.1","name":"RESET"},{"addr":"M0.2","name":"PISTAO"}]}]
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
I edited your post to fix it.
In a function node you could do something like this:
if (msg.payload == 'Liga') {
msg.payload = true;
if (msg.payload == 'Desliga') {
msg.payload = 1;
I'm unsure if you want the scond one to be a 1 or 0
"ReferenceError: msg is not defined"
It's giving this error, by the way where can I learn to program like this?
Put a debug node (set to display the complete msg object) on the output of the node feeding the function node and show the results.
Thereās a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Take a JavaScript tutorial like this
