Iframe not centered
Hi all
i want my iframe centered in the middle of my tab. see picture
can you help me out here ??
[{"id":"38aa91ac.81b13e","type":"function","z":"85c6adaf.bd9f5","name":"buienradar","func":"d = new Date().getTime()\n\no = \"<iframe src='https://gadgets.buienradar.nl/gadget/zoommap/?lat=52.26417&lng=4.63056&overname=2&zoom=6&naam=nieuw-vennep&size=2&voor=1' scrolling=no width=256 height=256 frameborder=no></iframe>\"\n\nreturn {template:o};","outputs":1,"noerr":0,"x":790,"y":1360,"wires":[["356499db.6e1596"]]},{"id":"356499db.6e1596","type":"ui_template","z":"85c6adaf.bd9f5","group":"973002a6.a4d9f","name":"","order":1,"width":6,"height":6,"format":"<center><div ng-bind-html=\"msg.payload\"></div></center>\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":1420,"y":1360,"wires":[[]]},{"id":"973002a6.a4d9f","type":"ui_group","z":"","name":"BuienRadar","tab":"70669a12.a74c34","order":10,"disp":true,"width":"6","collapse":false},{"id":"70669a12.a74c34","type":"ui_tab","z":"","name":"info","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
many thanks in advance
m
Did you try adding a 'style' to the iframe statement to set a margin?
yes but that did fix it .
i hope someone can help me with this
thx
m
Your response is confusing. Did that fix the issue or not. If not, exactly what did you add?
If it did fix it, please mark this solved.
I think surrounding the iframe tag in the function node by <div align=\"center\">and </div>
will do the job like it is done here:
o = "<div align=\"center\"><iframe src='https://gadg...></iframe></div>"
YESS!!!!! thats fixed it !!! many many thanx
i forgot ( i think ) the " in front of it
m
