IIoT with Node-RED and fischertechnik
fischertechnik is a German building system used as well to play, teach STEM and perform industrial simulations.
An interface board from Didacta Advance allows to use a Raspberry Pi to control a model. Along sequential programming with Pyhton, I've explored event-based programming with Node-RED to drive an automatic barrier model.
Sure, Linux could not offer real-time deterministic monitoring, but Node-RED makes IIoT really easy to use, with remote command-and-control dashboard .
Discover the project.
The initial flow wasn't very pretty so I opted for implementing FSM. I tested two nodes.
The node-red-contrib-finite-statemachine node requires to enter the states and transitions as a JSON sequence but displays them with a nice graph.
So I opted for the node-red-contrib-fsm node where states and transitions are defined in a table.
