I tried but it doesn't work
Nodered starts automatically. I'll try the command lines to see if I get the information.
my static folder is c:\temp
the file is saved in c:\temp\test\gate_open.gif
so i type :1881/test/gate_open.gif
Just as example from one of my computers, I have httpStatic: '/var/www/html/pics/'
So my images are in the pics folder and I can view them directly by typing http://192.168.0.241:1880/captured21.jpg
Therefore in my code in the ui-node I have:
<table>
<tr><!-- Row 1 -->
<td style="text-align: center"><img src="/captured31.jpg" id='p31' width="405px"/></td>
<td style="text-align: center"><img src="/captured12.jpg" id='p12' width="405px"/></td>
<td style="text-align: center"><img src="/captured41.jpg" id='p41' width="405px"/></td>
<td style="text-align: center"><img src="/captured11.jpg" id='p11' width="405px"/></td>
</tr>
</table>
<table>
<tr><!-- Row 2 -->
<td style="text-align: center"><img src="/captured32.jpg" id='p32' width="405px"/></td>
<td style="text-align: center"><img src="/captured22.jpg" id='p22' width="405px"/></td>
<td style="text-align: center"><img src="/captured21.jpg" id='p21' width="405px"/></td>
<!-- <td style="text-align: center"><img src="/captured42.jpg" id='p42' width="405px"/></td> -->
</tr>
</table>
As an example this works as expected. I think you need to double-check your settings
I think you found my problem !
I therefore have two instances of NodeRed, the first in this location ( This is where I make all my changes since installing Nodered ) :
The second instance found here :
I don't understand, I don't have the impression that this second instance was there a few days ago.
An idea ?
so make the httpstatic changes in the 'correct' settings file (which shows up in the startup log when you start node-red) and see if the problem is resolved ?
What is your ui-template size?
It's good, I found it, I work on my template directly on the web browser with the inspector element (f12), it works well. Thanks for taking the time to help me
glad you could find the solution. if you dont mind can you post the final solution picture and also please mark the relevant post as solution and mark the thread as closed.
