Image on dashboard
ok lets go
Update - you might have missed
Wanna give the simpler base64 method a go first?
you have established that the above works .. so why not simply try with one dot in the image src ./LogoNSH.png
with ./LogoNSH.pngit did not work
thanks @Steve-Mcl it worked with templateand base64 image
now i just need to resize the picture, can it be done by code, or need i new base64 image for each size i want the logo?
can't you just set the width ...
<img src="../LogoNSH.png" width="120px" /> or use CSS?
is not working
I think that might be something to do with angular JS stripping styling and properties from the HTML.
Try creating a style and CSS class that sets the image width etc then use that class name in your img tag
Google is your friend for that.
@Steve-Mcl thank you very much
