Node-red-contrib-image-output - IMAGE NOT LOADED
Following the tread: node-red-contrib-image-output
I only put and image, and it doesn't show on /ui neither /dashboard
I only have the output (image not loaded).
I resized it and neither works well.
Please, any help in order to show a single image?
Thanks,
Guillem
Finally,
I found other option in order to show image on node-red.
Install: node-red-contrib-ui-media (node) - Node-RED
what is your httpstatic setting ?
Directly with ui-media you could load an image (also a video).
