I send an image from python to node-red via websocket
the image appears in "image preview" in the working space which means that the connection is fine and the image was sent__ But it does not appear in the dashboard "I used dashboard media"
Any help ??
A little more information is needed.
- which ui node are you using (ui-media??)
- what does the msg you are sending look like? (Add a debug node - set to display the complete msg object - to the output of the node feeding the ui node and show what it displays
- when you say it shows up in image preview, what node are you talking about
- export and attach your flow
Thanks you for your time
I found a solution
I think my mistake was using ui-media instead of ui-template
now it is working and here is my solution in case someone needs it
- In Python I used flasks instead of websocket, I streamed my video over a link to node-red
"id": "d96c237d756d0e10",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "dfcc9a31.860948",
"type": "inject",
"z": "d96c237d756d0e10",
"name": "Start stream",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "",
"payload": "",
"payloadType": "date",
"x": 399.8333435058594,
"y": 340.00003814697266,
"db5630e7.83cdc"
"id": "6535feb.cbf33",
"type": "base64",
"name": "Encode",
"action": "",
"property": "payload",
"x": 790,
"y": 340,
"fb64a032.e945b"
"id": "fb64a032.e945b",
"type": "ui_template",
"group": "cc59dc7f5961ced9",
"name": "Display image",
"order": 1,
"width": "6",
"height": "6",
"format": "<img width=\"16\" height=\"16\" alt=\"stream test\" src=\"data:image/jpg;base64,{{msg.payload}}\" />\n",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 967.2569236755371,
"y": 340.4166660308838,
"id": "db5630e7.83cdc",
"type": "multipart-decoder",
"ret": "bin",
"url": "http://192.168.1.4:5000/video_feed",
"tls": "",
"delay": 0,
"maximum": "10000000",
"blockSize": "1",
"x": 600,
"y": 340,
"6535feb.cbf33"
"id": "3f3d533ce30e099b",
"type": "ui_button",
"order": 9,
"width": 0,
"height": 0,
"passthru": false,
"label": "Start Stream",
"tooltip": "",
"color": "",
"bgcolor": "red",
"className": "",
"icon": "",
"payload": "",
"topic": "topic",
"topicType": "msg",
"x": 410,
"y": 280,
"db5630e7.83cdc"
"id": "cc59dc7f5961ced9",
"type": "ui_group",
"name": "Default",
"tab": "6b5776c92264d7c2",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "6b5776c92264d7c2",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"disabled": false,
"hidden": false
