Hello
The node-red-contrib-image-output is fantastic, I just would like to display the same image in the dashboard ( buffer image in my case ).!
Thank you all
Hello
Thank you all
image buffer --> base64 --> function --> ui-template
function node
msg.payload = "data:image/png;base64," + msg.payload; //set correct mime type e.g. jpeg or gif etc
ui template node
<img src="{{payload}}" />
Thank ! you working
