Thanks in advance for your help. I have a table in MSSQL and I want to import these data into a table in my dashboard. I'm sure that query for selecting data is true but I have an error in my function for converting timestamp to date! I'm going to share my flow for simplicity to understand my case!
"id": "010882be62e27c36",
"type": "tab",
"label": "Flow 4",
"disabled": false,
"info": "",
"env": []
"id": "d4ecedcd76b49cf2",
"type": "group",
"z": "010882be62e27c36",
"style": {
"stroke": "#999999",
"stroke-opacity": "1",
"fill": "none",
"fill-opacity": "1",
"label": true,
"label-position": "nw",
"color": "#a4a4a4"
"nodes": [
"f582c6879cde83c3",
"e6f7c805b3694875",
"629163d58d2b2ff6",
"41acfbf0c664d218",
"118fb59630c5a5ea",
"eb48bcfb652ab2ea",
"30412c3aea9dcc5f",
"1868ac5e53302eb2",
"81ec6960c2706a5c",
"d02ac0f3a0ba2ef1",
"2818070ffbea4010",
"4b89b334b59d64cd",
"fd4616e5f68ecb6a",
"e5705cc287185d41",
"475b1d0bd7e58541",
"3d474e4fb542f1ae",
"132f01ebac382d08",
"71082a0b18ae90b4",
"eb4d2733562c4f37"
"x": 74,
"y": 139,
"w": 1232,
"h": 262
"id": "f582c6879cde83c3",
"type": "ui_button",
"g": "d4ecedcd76b49cf2",
"group": "acc5121b3da9d3b2",
"order": 6,
"width": 3,
"height": 1,
"passthru": false,
"label": "Import",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "1",
"payloadType": "str",
"topic": "topic",
"topicType": "msg",
"x": 150,
"y": 300,
"e6f7c805b3694875",
"629163d58d2b2ff6"
"id": "e6f7c805b3694875",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 330,
"y": 220,
"id": "629163d58d2b2ff6",
"type": "function",
"name": "Get parameters (1)",
"func": "msg = {\n BMU: flow.get(\"BMU\") ,\n sDate: \"'\" + flow.get(\"sDate\")+ \"'\",\n eDate: \"'\" + flow.get(\"eDate\")+ \"'\"\n};\n\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 260,
"41acfbf0c664d218",
"118fb59630c5a5ea"
"id": "41acfbf0c664d218",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 530,
"y": 220,
"id": "118fb59630c5a5ea",
"type": "function",
"name": "Func 1",
"func": "/******************************************************************/\n/*************************** Build Query **************************/\n\n// select = \" SELECT * FROM [MAXBESS_1].[dbo].[\" + msg.BMU + \"] WHERE Timestamp BETWEEN\n// + msg.sDate + \"AND\" + msg.eDate \";\n\n// select = \" SELECT * FROM [MAXBESS_1].[dbo].[\" + msg.BMU + \"] WHERE Timestamp BETWEEN \"+ msg.sDate + \" AND \" + msg.eDate ;\n\n\n// select =\"SELECT * FROM [MAXBESS_1].[dbo].[BMU2 ] WHERE Timestamp BETWEEN '2022-05-25 02:00:00' AND '2022-05-26 02:00:00'\"\n// msg.topic = select;\n// return msg;\n\n\nmsg.payload = \" SELECT * FROM [MAXBESS_1].[dbo].[\" + msg.BMU + \"] WHERE Timestamp BETWEEN \"+ msg.sDate + \" AND \" + msg.eDate ;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 530,
"y": 260,
"eb48bcfb652ab2ea",
"eb4d2733562c4f37"
"id": "eb48bcfb652ab2ea",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 730,
"y": 240,
"id": "30412c3aea9dcc5f",
"type": "ui_template",
"group": "",
"name": "Table template",
"order": 1,
"width": 30,
"height": 16,
"format": "\n \n<table style=\"width:100%\">\n <tr>\n <th>Index</th> \n <th>Timestamp</th>\n <th>Cell_V1</th> \n <th>Cell_V2</th>\n <th>Cell_V3</th>\n <th>Cell_V4</th>\n <th>Cell_V5</th>\n <th>Cell_V6</th>\n <th>Cell_V7</th>\n <th>Cell_V8</th>\n <th>Cell_V9</th>\n <th>Cell_V10</th>\n <th>Cell_V11</th>\n <th>Cell_V12</th>\n <th>Cell_V13</th>\n <th>Cell_V14</th>\n <th>Cell_V15</th>\n <th>Cell_V16</th>\n <!--<th>Cell_T1</th>-->\n <!--<th>Cell_T2</th>-->\n <!--<th>Cell_T3</th>-->\n <!--<th>Cell_T4</th>-->\n <!--<th>Cell_T5</th>-->\n <!--<th>Cell_T6</th>-->\n <!--<th>Cell_T7</th>-->\n <!--<th>Cell_T8</th>-->\n \n </tr>\n <tr ng-repeat=\"x in msg.payload | limitTo:500\">\n <td><center>{{$index}}</center></td>\n <td><center>{{msg.payload[$index].Timestamp}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V1}}</center></td> \n <td><center>{{msg.payload[$index].Cell_V2}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V3}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V4}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V5}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V6}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V7}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V8}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V9}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V10}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V11}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V12}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V13}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V14}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V15}}</center></td>\n <td><center>{{msg.payload[$index].Cell_V16}}</center></td>\n <!--<td><center>{{msg.payload[$index].Cell_T1}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T2}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T3}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T4}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T5}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T6}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T7}}</center></td>-->\n <!--<td><center>{{msg.payload[$index].Cell_T8}}</center></td>-->\n </tr>\n</table>\n",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 1200,
"y": 300,
"id": "1868ac5e53302eb2",
"type": "function",
"name": "Date to TS",
"func": "// for(var i = 0; i < msg.payload.length; i++){\n// // 9H = 32,400,000\n// var dd = new Date(parseInt((new Date(msg.payload[i].date).getTime()).toFixed(0)) - 32400000);\n// msg.payload[i].date = dd.toLocaleTimeString('it-IT');\n// }\n// return msg;\n\n\nfor(var i = 0; i < msg.payload.length; i++){\n \n date = new Date(msg.payload[i].Timestamp);\n msg.payload[i].Timestamp = date.toLocaleString();\n \n}\nreturn msg;",
"outputs": 1,
"noerr": 2,
"initialize": "",
"finalize": "",
"libs": [],
"x": 950,
"y": 280,
"2818070ffbea4010",
"4b89b334b59d64cd"
"id": "81ec6960c2706a5c",
"type": "debug",
"name": "RAW data",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"x": 940,
"y": 240,
"id": "d02ac0f3a0ba2ef1",
"type": "MSSQL",
"mssqlCN": "2f72498397332137",
"outField": "payload",
"returnType": 0,
"throwErrors": 1,
"query": "",
"modeOpt": "queryMode",
"modeOptType": "query",
"queryOpt": "payload",
"queryOptType": "editor",
"paramsOpt": "queryParams",
"paramsOptType": "none",
"rows": "rows",
"rowsType": "msg",
"params": [],
"x": 740,
"y": 280,
"id": "2818070ffbea4010",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1190,
"y": 220,
"id": "4b89b334b59d64cd",
"type": "ui_table",
"group": "30a5202a77f57bce",
"order": 1,
"width": 21,
"height": 7,
"columns": [],
"outputs": 0,
"cts": false,
"x": 1170,
"y": 260,
"id": "fd4616e5f68ecb6a",
"type": "comment",
"name": "Import data by Datetime (Cell data) ",
"info": "",
"x": 240,
"y": 180,
"id": "e5705cc287185d41",
"type": "function",
"name": "Get parameters(2)",
"func": "msg = {\n BMU: flow.get(\"BMU\") ,\n sDate_: \"'\" + flow.get(\"sDate_\"),\n sTime: flow.get(\"sTime\")+ \"'\" ,\n eDate_: \"'\" + flow.get(\"eDate_\"),\n eTime: flow.get(\"eTime\")+ \"'\"\n};\n\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 340,
"475b1d0bd7e58541",
"3d474e4fb542f1ae"
"id": "475b1d0bd7e58541",
"type": "function",
"name": "Func 2",
"func": "/******************************************************************/\n/*************************** Build Query **************************/\n\n\nmsg.payload = \" SELECT * FROM [MAXBESS_1].[dbo].[\" + msg.BMU + \"] WHERE Timestamp BETWEEN \"+ msg.sDate_+\" \"+ msg.sTime + \" AND \" + msg.eDate_+\" \"+msg.eTime;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 530,
"y": 340,
"71082a0b18ae90b4",
"eb4d2733562c4f37"
"id": "3d474e4fb542f1ae",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 530,
"y": 300,
"id": "132f01ebac382d08",
"order": 19,
"width": 3,
"height": 1,
"passthru": false,
"label": "import",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "1",
"topic": "topic",
"topicType": "msg",
"x": 150,
"y": 360,
"e5705cc287185d41"
"id": "71082a0b18ae90b4",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 730,
"y": 340,
"id": "eb4d2733562c4f37",
"type": "MSSQL",
"returnType": "1",
"throwErrors": 1,
"query": "",
"paramsOpt": "",
"paramsOptType": "editor",
"rows": "rows",
"rowsType": "msg",
"params": [],
"x": 740,
"y": 280,
"1868ac5e53302eb2"
"id": "acc5121b3da9d3b2",
"type": "ui_group",
"name": "Control unit",
"tab": "6149056c61e606b6",
"order": 1,
"disp": false,
"width": 7,
"collapse": false,
"className": ""
"id": "2f72498397332137",
"type": "MSSQL-CN",
"server": "localhost",
"port": "",
"encyption": false,
"trustServerCertificate": false,
"database": "MAXBESS_1",
"useUTC": false,
"connectTimeout": "",
"requestTimeout": "",
"cancelTimeout": "",
"pool": "",
"parseJSON": false,
"enableArithAbort": true
"id": "30a5202a77f57bce",
"type": "ui_group",
"name": "Database",
"order": 3,
"disp": true,
"width": 21,
"collapse": false,
"className": ""
"id": "6149056c61e606b6",
"type": "ui_tab",
"name": "Offline records",
"icon": "dashboard",
"order": 4,
"disabled": false,
"hidden": false
I would appreciate it if you help me to find the error.
