Importing the latest file(s) from a file folder into Node-RED
I am currently working with only one file where I am using the 'Read File' node to access it however the application I am dealing with requires me to automatically update the file every 6 hours. The file will have an alternative name each time and therefore I do not believe I can use the 'Read File' node. Both the CSV File as well as the TXT File will be located in the same directory and I will require both for my flow.
Can anyone provide any insight into this type of issue?
Welcome to the forum.
Could you use a Watch node to watch the folder for new files?
If you leave the Filename in the node config blank then you can (must) set it with msg.filename property on the input message.
Thanks! I was considering using this Node however I wasn’t sure of its full capabilities. The documentation felt vague to me. Is it a Boolean flag which turns true upon any changes to the folder?
Appreciate the help in advance.
I will look into this! Thanks for your reply.
I can’t recall exactly but just try it with a debug node attached and set to show complete msg.. I think it returns the changed file names and some other useful info. The sidebar help should tell you.
The watch node just outputs the name of any file that changes in the watched folder
Thank you all for the input. Below I will post the solution to the problem in my post.
Solution
As mentioned by various commenters, the 'Watch' node can be used to a specific file directory for any changes. If you would like the functionality mentioned in my post you can import the flow which I will attach at the bottom of this comment.
This flow will monitor a file directory for changes and when any 2 new files are added it will join them into a 'msg.payload' array. For my case I wanted the csv file which was stored in 'msg.payload[0]' to go to the above stream and then .txt file which was stored in the 'msg.payload[1]' to go to the below stream.
This flow is flexible and in the case you need to handle more files you can change the 'After a number of message parts' setting in the 'Join' node to your desired number of files.
Please note that for whichever reason in the 'Switch' node I could not define multiple outputs and direct the 'msg.filename' to their respective output so instead I added a 'Switch' node for each file I was trying to read.
        "id": "f99455d03588f4ae",
        "type": "tab",
        "label": "Flow 6",
        "disabled": false,
        "info": "",
        "env": []
        "id": "5e24854f53bf1b74",
        "type": "watch",
        "z": "f99455d03588f4ae",
        "name": "watch",
        "files": "",
        "recursive": "",
        "x": 130,
        "y": 240,
                "49d9727cf0c331fc"
        "id": "6b3cf284cad2620e",
        "type": "debug",
        "name": "debug 34",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1220,
        "y": 360,
        "id": "ae753ec17e7ac25e",
        "type": "file in",
        "name": "txt",
        "filename": "payload[1]",
        "filenameType": "msg",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 830,
        "y": 360,
                "6b3cf284cad2620e"
        "id": "f1167323c41b2a5e",
        "type": "file in",
        "name": "csv",
        "filename": "payload[0]",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 830,
        "y": 180,
                "6dcb09327f7aa3d0"
        "id": "6dcb09327f7aa3d0",
        "type": "debug",
        "name": "debug 38",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1220,
        "y": 180,
        "id": "03b9bb99a97ebab9",
        "type": "join",
        "mode": "custom",
        "build": "array",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "num",
        "reduceFixup": "",
        "x": 450,
        "y": 240,
                "0631ee86439ddd12",
                "9a1172a406afe598"
        "id": "49d9727cf0c331fc",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": "1",
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 290,
        "y": 240,
                "03b9bb99a97ebab9"
        "id": "330d60dd6a512ca3",
        "type": "comment",
        "name": "Test File Upload Func.",
        "info": "",
        "x": 180,
        "y": 280,
        "id": "0631ee86439ddd12",
        "type": "switch",
        "property": "filename",
        "rules": [
                "t": "eq",
                "v": "payload[1]",
                "vt": "msg"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 630,
        "y": 240,
                "f1167323c41b2a5e"
        "id": "5450ed817fab47fa",
        "type": "debug",
        "name": "debug 43",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1220,
        "y": 440,
        "id": "c1dfb7a8753f4abe",
        "type": "file in",
        "name": "txt",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 830,
        "y": 440,
                "5450ed817fab47fa"
        "id": "9a1172a406afe598",
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "payload[1]",
                "vt": "msg"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 630,
        "y": 300,
                "ae753ec17e7ac25e",
                "c1dfb7a8753f4abe"
