Importing two payloads as variables and use them for calculation
hi guys,
I wanna import two different payloads (with two different topics) to a function node and use them to calculate someting. At the end the result should be send out as a payload again.
I get the two values from another flow, that´s working. If I replace the two variables with static values, the funtion node works. But not using the payloads. Any hints for a beginner?
Regards
       "id": "df744e750e5a9e81",
       "type": "tab",
       "label": "Taupunkte",
       "disabled": false,
       "info": "",
       "env": []
       "id": "589a22c4f044264e",
       "type": "function",
       "z": "df744e750e5a9e81",
       "name": "Td außen",
       "func": "var es = { };\nvar ed = { };\nvar eln = { };\nvar td = { };\nvar msg1 = {};\nvar msg3 = {};\nmsg1.payload = msg.payload.tempout;\nmsg3.payload = msg.payload.humidityout;\nif (msg1.payload >= 0)\n{\n\t\t    es.payload = 6.1078*Math.pow(10,((7.5*msg1.payload)/(237.3 + msg1.payload)));\n\t\t    ed.payload = msg3.payload/100.0*es.payload;\n\t\t    eln.payload = Math.log10(ed.payload/6.1078);\n\t\t\ttd.payload = 237.3*eln.payload/(7.5 - eln.payload);\n}\nelse\n{\n\t\t    es.payload = 6.1078*Math.pow(10,((7.6*msg1.payload)/(240.7 + msg1.payload)));\n\t\t    ed.payload = msg3.payload/100.0*es.payload;\n\t\t    eln.payload = Math.log10(ed.payload/6.1078);\n\t\t\ttd.payload = 240.7*eln.payload/(7.6 - eln.payload);\n}\nreturn [msg1,msg3];",
       "outputs": 1,
       "timeout": 0,
       "noerr": 0,
       "initialize": "",
       "finalize": "",
       "libs": [],
       "x": 500,
       "y": 120,
               "a4cc9938fa255750"
       "id": "e3019f3175327953",
       "type": "link in",
       "name": "Humidity out",
       "links": [
           "995f7c2d3ba33d99"
       "x": 65,
       "y": 140,
               "da8bfa18928117f9"
       "id": "33412de7df28bca2",
       "type": "link in",
       "name": "Temp out",
       "links": [
           "ffc8b882aa95a7cd"
       "x": 65,
       "y": 100,
               "f860fc114b0a2b09"
       "id": "a4cc9938fa255750",
       "type": "debug",
       "name": "debug 11",
       "active": true,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "complete": "payload",
       "targetType": "msg",
       "statusVal": "",
       "statusType": "auto",
       "x": 1100,
       "y": 100,
       "id": "da8bfa18928117f9",
       "type": "change",
       "rules": [
               "t": "set",
               "p": "topic",
               "pt": "msg",
               "to": "humidityout",
               "tot": "str"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 200,
       "y": 140,
               "54d2c21d96f0c541",
               "589a22c4f044264e"
       "id": "35bcef6655a8a3ca",
       "type": "debug",
       "name": "tempout",
       "active": true,
       "tosidebar": true,
       "console": false,
       "tostatus": true,
       "statusVal": "payload",
       "x": 400,
       "y": 40,
       "id": "54d2c21d96f0c541",
       "type": "debug",
       "name": "humidityout",
       "active": true,
       "tosidebar": true,
       "console": false,
       "tostatus": true,
       "x": 410,
       "y": 200,
       "id": "f860fc114b0a2b09",
       "type": "change",
       "rules": [
               "t": "set",
               "p": "topic",
               "pt": "msg",
               "to": "tempout",
               "tot": "str"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 200,
       "y": 100,
               "35bcef6655a8a3ca",
               "589a22c4f044264e"
Hi @Lenaschitz,
You are almost there but you need to use a join node so that the humidity and temperature are both available in a single message as msg.payload.humidityout and msg.payload.tempout.
A function node. like almost all nodes, only sees one message at a time.
Try this
[{"id":"589a22c4f044264e","type":"function","z":"df744e750e5a9e81","name":"Td außen","func":"var es = { };\nvar ed = { };\nvar eln = { };\nvar td = { };\nvar msg1 = {};\nvar msg3 = {};\nmsg1.payload = msg.payload.tempout;\nmsg3.payload = msg.payload.humidityout;\nif (msg1.payload >= 0)\n{\n\t\t    es.payload = 6.1078*Math.pow(10,((7.5*msg1.payload)/(237.3 + msg1.payload)));\n\t\t    ed.payload = msg3.payload/100.0*es.payload;\n\t\t    eln.payload = Math.log10(ed.payload/6.1078);\n\t\t\ttd.payload = 237.3*eln.payload/(7.5 - eln.payload);\n}\nelse\n{\n\t\t    es.payload = 6.1078*Math.pow(10,((7.6*msg1.payload)/(240.7 + msg1.payload)));\n\t\t    ed.payload = msg3.payload/100.0*es.payload;\n\t\t    eln.payload = Math.log10(ed.payload/6.1078);\n\t\t\ttd.payload = 240.7*eln.payload/(7.6 - eln.payload);\n}\nreturn [msg1,msg3];","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":120,"wires":[["a4cc9938fa255750"],["b8d5476b4242a6aa"]]},{"id":"a4cc9938fa255750","type":"debug","z":"df744e750e5a9e81","name":"msg1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":100,"wires":[]},{"id":"da8bfa18928117f9","type":"change","z":"df744e750e5a9e81","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"humidityout","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":160,"wires":[["54d2c21d96f0c541","dcca29ba6dddb46b"]]},{"id":"35bcef6655a8a3ca","type":"debug","z":"df744e750e5a9e81","name":"tempout","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":460,"y":60,"wires":[]},{"id":"54d2c21d96f0c541","type":"debug","z":"df744e750e5a9e81","name":"humidityout","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":470,"y":180,"wires":[]},{"id":"f860fc114b0a2b09","type":"change","z":"df744e750e5a9e81","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"tempout","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":80,"wires":[["35bcef6655a8a3ca","dcca29ba6dddb46b"]]},{"id":"dcca29ba6dddb46b","type":"join","z":"df744e750e5a9e81","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":450,"y":120,"wires":[["589a22c4f044264e","5ec7c68d4ca8a604"]]},{"id":"5ec7c68d4ca8a604","type":"debug","z":"df744e750e5a9e81","name":"Joined payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":60,"wires":[]},{"id":"24e426bdec5f9431","type":"inject","z":"df744e750e5a9e81","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"85","payloadType":"num","x":90,"y":140,"wires":[[]]},{"id":"7acf594ecde0d970","type":"inject","z":"df744e750e5a9e81","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"85","payloadType":"num","x":90,"y":140,"wires":[["da8bfa18928117f9"]]},{"id":"7334d6d8751fc2d0","type":"inject","z":"df744e750e5a9e81","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"87","payloadType":"num","x":90,"y":180,"wires":[["da8bfa18928117f9"]]},{"id":"82bd99e51ba158b2","type":"inject","z":"df744e750e5a9e81","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"22","payloadType":"num","x":90,"y":100,"wires":[["f860fc114b0a2b09"]]},{"id":"bf5031b05ae89954","type":"inject","z":"df744e750e5a9e81","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"21","payloadType":"num","x":90,"y":60,"wires":[["f860fc114b0a2b09"]]},{"id":"b8d5476b4242a6aa","type":"debug","z":"df744e750e5a9e81","name":"msg3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":140,"wires":[]}]
There are a couple of things about your function node too.
  • You have return [msg1,msg3]; which implies that the node has two outputs. The Setup tab lets you control this.
  • You calculate values for the objects es, ed, eln and td but you don't pass these on as message properties for use further along the wires
Hi jbudd,
many thanks for your reply, works now also with real data. Did read already a lot about the join node, but wasn´t aware to add a "2" for handling two messages instead of one.
And in the end I need td, but I was sure, were the issue comes from, so I wanted to see if both variables pass the function node.
Many thanks for your support.
