IncomingMessage
O node-red estava funcionando ok mas derrepente começou a ocorrer este erro abaixo, isto quando faço deploy. Alguem pode me dizer o que pode estar acontecendo.. And this error is intermittent, that is, there is a deploy that the error occurs and there is a deloy that does not occur.
BadRequestError: request aborted
at IncomingMessage.onAborted (C:\Users\lucas.horst\AppData\Roaming\npm\node_modules\node-red\node_modules\raw-body\index.js:231:10)
at IncomingMessage.emit (events.js:315:20)
at abortIncoming (_http_server.js:561:9)
at socketOnClose (_http_server.js:554:3)
at Socket.emit (events.js:327:22)
at TCP. (net.js:673:12)
Hello Lucas.Horst,
Bienvenido - welcome to the forum :slight_smile:
I guess it would help to have the whole question in English and some flow examples, where the error occurs and a debug output of the message, which produces the error. Are you using any webhooks?
Cheers
Ranki
