Greetings. New to the node-red paltform ( and most else ) but was wanting to read a text file from a file and seemed to be getting only a part of it as output. Other text files read completely.
This text file is a result of a hardware device string throwing out data. The idea is to then map it with known header tags and get a sensible output.
Any ideas guys?
here is the code.
[{"id":"cd014bcf.450f38","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b772ca63.471af","type":"debug","z":"cd014bcf.450f38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":648,"y":143,"wires":[]},{"id":"3fae45ac.b8a56a","type":"inject","z":"cd014bcf.450f38","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":107,"y":111,"wires":[["e7f50c8b.da80e"]]},{"id":"e7f50c8b.da80e","type":"file in","z":"cd014bcf.450f38","name":"","filename":"/Users/Vaishakh/Desktop/data.txt","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":373,"y":124,"wires":[["b772ca63.471af"]]}]
Here is the text file:
20191025104608,D,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,        ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   HIGH,    NORM,    NORM,    NORM,    NORM,A   LOW ,I   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,        ,    RUN ,        ,    RUN ,    S/B ,    S/B ,    RUN ,    RUN ,    S/B ,    S/B ,    RUN ,    S/B ,        ,    STOP,        ,        ,    STOP,    RUN ,    STOP,    STOP,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,R   LOW ,R   LOW ,R   NORM,    NORM,R   LOW ,R   NORM,R   LOW ,R   NORM,    NORM,    NORM,    NORM,R   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,R   LOW ,R   LOW ,R   NORM,    NORM,R   LOW ,R   NORM,R   LOW ,R   NORM,    NORM,    NORM,    NORM,R   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    S/B ,    NORM,    NORM,I   NORM,    NORM,    STOP,    NORM,    NORM,    RUN ,    NORM,    NORM,    RUN ,    NORM,    NORM,    STOP,    NORM,    NORM,    STOP,    STOP,    STOP,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    SUP ,    RUN ,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   ALAM,    STOP,    NORM,A   TRBL,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    OFF ,    ON  ,    ON  ,    OFF ,    OFF ,    OFF ,    OFF ,    OFF ,    OFF ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    OFF ,    OFF ,    OFF ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   ABNR,    NORM5120191025104613,P,58865526,13142.58,  729.33,  728.01,    3896,    8373,    6658,    2181, 8140.18,13044.26,10083.21,12178.39, 9468.50,12882.50,11841.47,11117.47,11695.39, 9295.15, 8716.16,12155.37,  700.14, 1809.35,  848.21, 1499.05, 1911.39, 2439.32,18942.39, 8102.11,  319.58,  217.01,10127.12, 9581.17, 8700.19, 8151.08,   11.22,11388.33, 4488.19,16560.56, 8123.37, 1909.47, 1267.31,18015.57,20120.29,20201.52, 9347.12, 9453.48, 4422.43,12280.14,    0.37,23070.49,23070.49*5C20191025104613,A,    80.7,    80.6,   13033,    74.2,   2.253,    56.0,    56.1,    56.5,    58.1,    59.0,    59.1,   0.529,   0.531,    84.2,    91.2,    90.4,    92.0,    91.8,    90.6,    91.3,   0.163,   0.249,   0.246,    52.1,    65.3,    38.3,    38.6,    51.6,    60.1,    56.2,    56.8,    56.8,    57.0,    56.8,    56.9,   0.697,   133.2,    99.8,    69.2,   0.312,   2.156,   3.692,   0.204,   0.100,   0.121,   2.357,   4.389,   357.6,   350.1,   332.9,   339.7,   335.2,   343.6,    14.4,     6.9,   -10.3,    -3.5,    -8.0,     0.4,   343.2,   395.2,   254.2,   0.182,    48.4,   0.621,R   57.9,R   65.5,    43.5,    48.7,       0,R   59.1,R   64.4,    52.1,    47.6,       0,    57.0,    72.9,   421.5,   422.7,     298,   2.252,   2.125,   0.703*5C20191025104613,D,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,        ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   HIGH,    NORM,    NORM,    NORM,    NORM,A   LOW ,I   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,        ,    RUN ,        ,    RUN ,    S/B ,    S/B ,    RUN ,    RUN ,    S/B ,    S/B ,    RUN ,    S/B ,        ,    STOP,        ,        ,    STOP,    RUN ,    STOP,    STOP,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,R   LOW ,R   LOW ,R   NORM,    NORM,R   LOW ,R   NORM,R   LOW ,R   NORM,    NORM,    NORM,    NORM,R   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,R   LOW ,R   LOW ,R   NORM,    NORM,R   LOW ,R   NORM,R   LOW ,R   NORM,    NORM,    NORM,    NORM,R   NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    S/B ,    NORM,    NORM,I   NORM,    NORM,    STOP,    NORM,    NORM,    RUN ,    NORM,    NORM,    RUN ,    NORM,    NORM,    STOP,    NORM,    NORM,    STOP,    STOP,    STOP,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    STOP,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    SUP ,    RUN ,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   ALAM,    STOP,    NORM,A   TRBL,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    OFF ,    ON  ,    ON  ,    OFF ,    OFF ,    OFF ,    OFF ,    OFF ,    OFF ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    OFF ,    OFF ,    OFF ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,A   ABNR,    NORM*5B20191025104618,P,58865532,13142.58,  729.33,  728.01,    3896,    8373,    6658,    2181, 8140.18,13044.26,10083.21,12178.39, 9468.50,12882.50,11841.47,11117.47,11695.39, 9295.15, 8716.16,12155.37,  700.14, 1809.35,  848.21, 1499.05, 1911.39, 2439.32,18942.39, 8102.11,  319.58,  217.01,10127.12, 9581.17, 8700.19, 8151.08,   11.22,11388.33, 4488.19,16560.56, 8123.37, 1909.47, 1267.31,18015.57,20120.29,20201.52, 9347.12, 9453.48, 4422.43,12280.14,    0.37,23070.49,23070.49*5220191025104618,A,    80.5,    80.5,   13031,    74.9,   2.253,    56.0,    56.1,    56.5,    58.1,    59.0,    59.1,   0.529,   0.529,    84.2,    91.2,    90.4,    92.0,    91.8,    90.6,    91.3,   0.163,   0.243,   0.248,    52.1,    65.3,    38.3,    38.6,    51.6,    60.1,    56.2,    56.8,    56.7,    57.0,    56.7,    56.8,   0.696,   133.2,    99.8,    69.2,   0.312,   2.156,   3.696,   0.204,   0.100,   0.121,   2.357,   4.389,   357.6,   350.0,   332.9,   339.7,   335.1,   343.6,    14.4,     6.9,   -10.3,    -3.5,    -8.0,     0.4,   343.2,   395.1,   254.2,   0.182,    48.4,   0.622,R   57.9,R   65.5,    43.5,    48.7,       0,R   59.1,R   64.4,    52.1,    47.6,       0,    57.0,    72.9,   421.5,   422.7,     297,   2.251,   2.125,   0.703*5820191025104618,D,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    RUN ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    STOP,        ,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,    NORM,
