Increasing value font size
I'm trying to increase the size of the number in the current value field. I tried it with <font size =25> {{msg.payload}}
in the value format. But that doesnt't work after a certain font size. Is there any other way to do it?
Best regards
Here is my flow
[{"id":"3e53ca35.c83ac6","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"c09896c2.ab8e08","type":"ui_text","z":"3e53ca35.c83ac6","group":"b056afdb.c7064","order":1,"width":5,"height":1,"name":"","label":"","format":"<font size =25> {{msg.payload}}","layout":"col-center","className":"","x":350,"y":580,"wires":[]},{"id":"62302add.4be644","type":"ui_text","z":"3e53ca35.c83ac6","group":"81ca356d.285a68","order":1,"width":5,"height":1,"name":"","label":"","format":"<font size =25> {{msg.payload}}","layout":"col-center","className":"","x":570,"y":120,"wires":[]},{"id":"dbdd74ea.499358","type":"ui_text","z":"3e53ca35.c83ac6","group":"8e0a4637.5f0ed8","order":1,"width":5,"height":1,"name":"","label":"","format":"<font size =25> {{msg.payload}}","layout":"col-center","className":"","x":570,"y":300,"wires":[]},{"id":"f85fe283.6d61","type":"ui_text","z":"3e53ca35.c83ac6","group":"bf6ba59b.615928","order":1,"width":5,"height":1,"name":"","label":"","format":"<font size =25> {{msg.payload}}","layout":"col-center","className":"","x":570,"y":460,"wires":[]},{"id":"f880659.057b898","type":"ui_text","z":"3e53ca35.c83ac6","group":"f3c27b0f.eb2868","order":1,"width":10,"height":6,"name":"current value","label":"","format":"<font size =25> {{msg.payload}}","layout":"col-center","className":"","x":370,"y":660,"wires":[]},{"id":"f75fbfdc.8181f","type":"s7 in","z":"3e53ca35.c83ac6","endpoint":"17b58fa0.732d4","mode":"single","variable":"Zähler","diff":false,"name":"","x":110,"y":300,"wires":[["71ba5745.f20638","52824021.78eea","588c8c11.c5c354"]]},{"id":"1ce58b1d.b421f5","type":"s7 in","z":"3e53ca35.c83ac6","endpoint":"17b58fa0.732d4","mode":"single","variable":"Zähler","diff":false,"name":"placeholder","x":190,"y":620,"wires":[["f880659.057b898","c09896c2.ab8e08"]]},{"id":"52824021.78eea","type":"gate","z":"3e53ca35.c83ac6","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":450,"y":120,"wires":[["62302add.4be644"]]},{"id":"71ba5745.f20638","type":"gate","z":"3e53ca35.c83ac6","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":450,"y":300,"wires":[["dbdd74ea.499358"]]},{"id":"588c8c11.c5c354","type":"gate","z":"3e53ca35.c83ac6","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":450,"y":460,"wires":[["f85fe283.6d61"]]},{"id":"b73590d.03f8c7","type":"inject","z":"3e53ca35.c83ac6","name":"","topic":"control","payload":"open","payloadType":"str","repeat":"","crontab":"00 14 * * *","once":false,"onceDelay":0.1,"x":140,"y":60,"wires":[["129e0b67.53ef15","d0853c05.b2ccd"]]},{"id":"ab42e727.f26098","type":"inject","z":"3e53ca35.c83ac6","name":"","topic":"control","payload":"open","payloadType":"str","repeat":"","crontab":"00 22 * * *","once":false,"onceDelay":0.1,"x":140,"y":240,"wires":[["f2cb1d94.9b2f3","95667ab3.868188"]]},{"id":"dd4c40d.569f7c","type":"inject","z":"3e53ca35.c83ac6","name":"","topic":"control","payload":"open","payloadType":"str","repeat":"","crontab":"00 06 * * *","once":false,"onceDelay":0.1,"x":140,"y":400,"wires":[["b2a497c6.b73718","cd97ec07.1f2d5"]]},{"id":"129e0b67.53ef15","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"str","ontimeoutval":"close","duration":"300","units":"ms","name":"","x":310,"y":80,"wires":[["52824021.78eea"]]},{"id":"f2cb1d94.9b2f3","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"str","ontimeoutval":"close","duration":"300","units":"ms","name":"","x":310,"y":260,"wires":[["71ba5745.f20638"]]},{"id":"b2a497c6.b73718","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"str","ontimeoutval":"close","duration":"300","units":"ms","name":"","x":310,"y":420,"wires":[["588c8c11.c5c354"]]},{"id":"39837724.f01bf8","type":"delay","z":"3e53ca35.c83ac6","name":"","pauseType":"delay","timeout":"600","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":40,"wires":[["676d2337.6f5aac"]]},{"id":"676d2337.6f5aac","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"bool","ontimeoutval":"false","duration":"1","units":"s","name":"","x":730,"y":40,"wires":[["8c545de6.2c348"]]},{"id":"d0853c05.b2ccd","type":"change","z":"3e53ca35.c83ac6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":40,"wires":[["39837724.f01bf8"]]},{"id":"55fa2e6b.98fc7","type":"delay","z":"3e53ca35.c83ac6","name":"","pauseType":"delay","timeout":"600","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":220,"wires":[["40bfb532.e294dc"]]},{"id":"8c545de6.2c348","type":"s7 out","z":"3e53ca35.c83ac6","endpoint":"17b58fa0.732d4","variable":"test","name":"","x":970,"y":220,"wires":[]},{"id":"40bfb532.e294dc","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"bool","ontimeoutval":"false","duration":"1","units":"s","name":"","x":730,"y":220,"wires":[["8c545de6.2c348"]]},{"id":"95667ab3.868188","type":"change","z":"3e53ca35.c83ac6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":220,"wires":[["55fa2e6b.98fc7"]]},{"id":"e8c2a67a.4d43b8","type":"delay","z":"3e53ca35.c83ac6","name":"","pauseType":"delay","timeout":"600","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":380,"wires":[["702c204c.d69d1"]]},{"id":"702c204c.d69d1","type":"timeouttrigger","z":"3e53ca35.c83ac6","ontimeouttype":"bool","ontimeoutval":"false","duration":"1","units":"s","name":"","x":730,"y":380,"wires":[["8c545de6.2c348"]]},{"id":"cd97ec07.1f2d5","type":"change","z":"3e53ca35.c83ac6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":380,"wires":[["e8c2a67a.4d43b8"]]},{"id":"ea1586d6.897978","type":"ui_template","z":"3e53ca35.c83ac6","group":"e7c8e0ca.8d2b9","name":"Clock Toolbar","order":2,"width":"0","height":"0","format":"<script id=\"titleScript\" type=\"text/javascript\">\n\n$(function() {\n    if($('.md-toolbar-tools').length != 0){\n        loadClock();\n    }else setTimeout(loadClock, 500)\n});\n\nfunction loadClock(){\n    $('#clock').remove();\n    var toolbar = $('.md-toolbar-tools');\n    \n    var div = $('<div/>');\n    var p = $('<p/ id=\"clock\">');\n    \n    div.append(p);\n    div[0].style.margin = '5px 5px 5px auto';\n    toolbar.append(div);\n\n    function displayTitle(lh) {\n        p.text(lh); \n    }\n    \n    function upTime() {\n        var d = new Date();\n        p.text(d.toLocaleString());\n    }\n\n    if(document.clockInterval){ \n            clearInterval(document.clockInterval);\n            document.clockInterval = null;\n    }\n        \n    document.clockInterval = setInterval(upTime,1000);\n}\n\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":1220,"y":60,"wires":[[]]},{"id":"339829df.c07666","type":"comment","z":"3e53ca35.c83ac6","name":"F","info":"Frühschicht","x":710,"y":120,"wires":[]},{"id":"f529b725.f5db18","type":"comment","z":"3e53ca35.c83ac6","name":"S","info":"","x":710,"y":300,"wires":[]},{"id":"885f1ffc.5cb5e","type":"comment","z":"3e53ca35.c83ac6","name":"N","info":"","x":710,"y":460,"wires":[]},{"id":"b056afdb.c7064","type":"ui_group","z":"","name":"Produktzähler gesamt","tab":"171d8214.95a08e","order":3,"disp":true,"width":5,"collapse":false,"className":""},{"id":"81ca356d.285a68","type":"ui_group","z":"","name":"Frühschicht","tab":"171d8214.95a08e","order":4,"disp":true,"width":5,"collapse":false,"className":""},{"id":"8e0a4637.5f0ed8","type":"ui_group","z":"","name":"Spätschicht","tab":"171d8214.95a08e","order":5,"disp":true,"width":5,"collapse":false,"className":""},{"id":"bf6ba59b.615928","type":"ui_group","z":"","name":"Nachtschicht","tab":"171d8214.95a08e","order":6,"disp":true,"width":5,"collapse":false,"className":""},{"id":"f3c27b0f.eb2868","type":"ui_group","z":"","name":"current value","tab":"171d8214.95a08e","order":1,"disp":true,"width":"10","collapse":false,"className":""},{"id":"17b58fa0.732d4","type":"s7 endpoint","z":"","transport":"iso-on-tcp","address":"192.168.178.10","port":"102","rack":"0","slot":"2","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","busaddr":"2","cycletime":"100","timeout":"2000","name":"","vartable":[{"addr":"DB2,X0.0","name":"test"},{"addr":"DB2,DI6","name":"dword"},{"addr":"DB2,WORD10","name":"Zähler"}]},{"id":"e7c8e0ca.8d2b9","type":"ui_group","z":"","name":"hidden_group","tab":"","order":1,"disp":false,"width":"6","collapse":false},{"id":"171d8214.95a08e","type":"ui_tab","z":"","name":"MSK Produktzähler","icon":"dashboard","disabled":false,"hidden":false}]
You can give the current value field a custom class and use a UI template node to style it
Thanks!
I have tried so many posts in the Forum to get around template node settings to get font size customization, by far this is the simplest and easiest i could comprehend. thanks.
So this setting is applicable to all the GROUPS in the TAB ? and not applicable to another TAB. am i right in saying that ?
can we get FONT COLOR also in the template setting ? i am currently doing <font color=red> in the text node itself.
If you change the template from "widget in group" to "in the page header" it will be applicable on all tabs.
Great. That is awesome
That worked perfectly, thank you. Is it possible to do this with the group names as well? And Color
best regards
Yes you can. I think it depends on the theme settings in Dashboard (on the Site tab) though.
And I don't know how much you can achieve by changing the template itself.
Here is the same Group having class "red" with two different Site settings.
Edit - only the dashboard group Column1 is given the custom class, the text widgets are vanilla.
<style>
.red p {
    color:red;
</style>
Actually I suggest using a much more specific CSS selector than ".red p" or sooner or later you will have to make your definitions !important, the sign of desperation :grinning:
