Just as one idea …
[{"id":"7ba617c.f70ffe8","type":"ui_button","z":"dfeaf865.51c758","name":"","group":"cd8751a3.f6fba","order":7,"width":0,"height":0,"passthru":false,"label":"Subir temperatura","color":"red","bgcolor":"#E9967A","icon":"fa-arrow-circle-up","payload":"1","payloadType":"num","topic":"","x":170,"y":4600,"wires":[["4a536d89.12adc4"]]},{"id":"10c3a218.e230fe","type":"ui_button","z":"dfeaf865.51c758","name":"","group":"cd8751a3.f6fba","order":8,"width":0,"height":0,"passthru":false,"label":"Bajar temperatura","color":"blue","bgcolor":"#3FADB5","icon":"fa-arrow-circle-down","payload":"1","payloadType":"num","topic":"","x":150,"y":4680,"wires":[["107c94cb.1ae2bb"]]},{"id":"6550849b.6f0b3c","type":"inject","z":"dfeaf865.51c758","name":"","topic":"","payload":"21","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":"","x":299,"y":4742,"wires":[["c0f15889.239e98"]]},{"id":"25ce51ea.8d375e","type":"change","z":"dfeaf865.51c758","name":"","rules":[{"t":"set","p":"decrement","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":4680,"wires":[["a66f041.d5e9bf8"]]},{"id":"9b2069d5.c3d768","type":"change","z":"dfeaf865.51c758","name":"","rules":[{"t":"set","p":"increment","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":4600,"wires":[["a66f041.d5e9bf8"]]},{"id":"c0f15889.239e98","type":"change","z":"dfeaf865.51c758","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"21","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":495,"y":4740,"wires":[["a66f041.d5e9bf8"]]},{"id":"a66f041.d5e9bf8","type":"counter","z":"dfeaf865.51c758","name":"","init":"17","step":1,"lower":"17","upper":"30","mode":"decrement","outputs":"2","x":740,"y":4740,"wires":[["da10f784.81b1e8","8b0b857e.a512a8"],[]]},{"id":"50fcd1dd.64875","type":"ui_button","z":"dfeaf865.51c758","name":"","group":"cd8751a3.f6fba","order":10,"width":"3","height":"1","passthru":false,"label":"Max temp","color":"red","bgcolor":"#E9967A","icon":"fa-thermometer-full ","payload":"30","payloadType":"num","topic":"","x":260,"y":4820,"wires":[["e889f3be.78a8d"]]},{"id":"81fc8451.f6d268","type":"ui_button","z":"dfeaf865.51c758","name":"","group":"cd8751a3.f6fba","order":9,"width":"3","height":"1","passthru":false,"label":"Min temp","color":"blue","bgcolor":"#3FADB5","icon":"fa-thermometer-empty","payload":"17","payloadType":"num","topic":"","x":264,"y":4866,"wires":[["b4f5cda0.cd1a7"]]},{"id":"594ae56.d2fc91c","type":"change","z":"dfeaf865.51c758","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"30","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":4820,"wires":[["a66f041.d5e9bf8"]]},{"id":"942131df.140b7","type":"change","z":"dfeaf865.51c758","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"17","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":4860,"wires":[["a66f041.d5e9bf8"]]},{"id":"4a536d89.12adc4","type":"switch","z":"dfeaf865.51c758","name":"","property":"AC_salon","propertyType":"global","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","outputs":1,"x":350,"y":4600,"wires":[["9b2069d5.c3d768"]]},{"id":"107c94cb.1ae2bb","type":"switch","z":"dfeaf865.51c758","name":"","property":"AC_salon","propertyType":"global","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","outputs":1,"x":330,"y":4680,"wires":[["25ce51ea.8d375e"]]},{"id":"e889f3be.78a8d","type":"switch","z":"dfeaf865.51c758","name":"","property":"AC_salon","propertyType":"global","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","outputs":1,"x":410,"y":4820,"wires":[["594ae56.d2fc91c"]]},{"id":"b4f5cda0.cd1a7","type":"switch","z":"dfeaf865.51c758","name":"","property":"AC_salon","propertyType":"global","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","outputs":1,"x":410,"y":4860,"wires":[["942131df.140b7"]]},{"id":"da10f784.81b1e8","type":"ui_gauge","z":"dfeaf865.51c758","name":"consigna","group":"cd8751a3.f6fba","order":6,"width":"0","height":"0","gtype":"gage","title":"Consigna","label":"ºC","format":"{{value}}","min":"17","max":"30","colors":["#0728ad","#ff6317","#ca3838"],"seg1":"22","seg2":"25","x":840,"y":4660,"wires":[]},{"id":"cd8751a3.f6fba","type":"ui_group","z":"","name":"AC Dormitorio","tab":"b5ad9abd.3a6c38","order":3,"disp":true,"width":"6"},{"id":"b5ad9abd.3a6c38","type":"ui_tab","z":"","name":"C. REMOTOS","icon":"wifi","order":3}]
