InfluxDB | Delete measurement information between to times
Hello
I need to delet some datas in a measurement
I know the measurement is in Egolzwil
need to delete all
information in Egolzwil
from the 2021-01-28 23:36:30 till 2021-01-29 16:56:30
how to do this correct way?
have a nice day
vinc
InfluxDB shell version: 1.8.3
The influx docs are quite good. See Manage your database using InfluxQL | InfluxDB OSS 1.8 Documentation
go to the Database and do a
DELETE FROM "Egolzwil" WHERE time > '2021-01-28T23:00:00Z'
but did not find out how to cut between to date/time
and because it did work have no option to test it again :wink:
I imagine you wanted
DELETE FROM "Egolzwil" WHERE time > '2021-01-28T23:00:00Z' and time <= ....
Whenever you are about to do a DELETE you can first try it with SELECT * FROM ... to check which records it will delete.
yes it works like you wrote it.
Merci @Colin
DELETE FROM "Egolzwil" WHERE time > '2021-01-27T22:55:00Z' and time <= '2021-01-28T23:00:00Z'
