InfluxdB out node
Does anybody know how to pass a payload, topic or flow variable into the InfluxDB Out node, as the measurement name/field?
Usually {{payload}} or {{msg.topic}} works in order to insert the payload/topic into another node. But clearly that doesn’t work for the ‘influx out node’
It is in the help text for the node
"If the measurement field is not set in the node configuration, the user can send in data with a specified measurement name in msg.measurement to overwrite the measurement field in the configuration of the node."
