Inject dynamical variables in a node
I read data from an electronic card integrated in a climatic chamber.
I use the node-red-contrib-telnet-client to do that (I can't use s7 nodes for example).
Because we have multiples chambers, I created an object (in a function) where there is the list of the chambers with their own properties (IP address, name, port). In the telnet nodes, I would like to inject these parameters in the fields, and not directly a value. In fact, I would like to establish the connection for one chamber, then read and treat data, and finally wait a little in order to do this cycle for each chamber (the delay is here for avoiding communication saturation).
How could I make a loop for this ? I just have to change the 3 fields in the "Connection" field of the telnet node. For instance, in the "Port" field in the telnet node, I can only put a number value. I can not enter a parameter like "msg.payload.port".
Here is my function with the list of the chambers :
let Etuves = {
    nomEtuve: "",
    adresseIP: "",
    port: 888,
let etuve217 = Object.create(Etuves);
etuve217.nomEtuve = "Etuve 217";
etuve217.adresseIP = "xx.xx.xx.217";
let etuve109 = Object.create(Etuves);
etuve109.nomEtuve = "Etuve 109";
etuve109.adresseIP = "xx.xx.xx.109";
let etuve111 = Object.create(Etuves);
etuve111.nomEtuve = "Etuve 111";
etuve111.adresseIP = "xx.xx.xx.111";
let etuve216 = Object.create(Etuves);
etuve216.nomEtuve = "Etuve 216";
etuve216.adresseIP = "xx.xx.xx.216";
let tab = [];
tab.push(etuve217)
tab.push(etuve109)
tab.push(etuve111)
tab.push(etuve216)
return {payload: tab}
You will find below the flow :
        "id": "1a7e315fd340af0f",
        "type": "tab",
        "label": "Flow 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "a8c1d9281aea0673",
        "type": "function",
        "z": "1a7e315fd340af0f",
        "name": "List of the chambers",
        "func": "let Etuves = {\n    nomEtuve: \"\",\n    adresseIP: \"\",\n    port: 888,\n}\n\n\n\nlet etuve217 = Object.create(Etuves);\netuve217.nomEtuve = \"Etuve 217\";\netuve217.adresseIP = \"xx.xx.xx.217\";\n\n\nlet etuve109 = Object.create(Etuves);\netuve109.nomEtuve = \"Etuve 109\";\netuve109.adresseIP = \"xx.xx.xx.109\";\n\n\nlet etuve111 = Object.create(Etuves);\netuve111.nomEtuve = \"Etuve 111\";\netuve111.adresseIP = \"xx.xx.xx.111\";\n\n\nlet etuve216 = Object.create(Etuves);\netuve216.nomEtuve = \"Etuve 216\";\netuve216.adresseIP = \"xx.xx.xx.216\";\n\n\nlet tab = [];\ntab.push(etuve217)\ntab.push(etuve109)\ntab.push(etuve111)\ntab.push(etuve216)\n\nreturn {payload: tab}\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 360,
                "133e8899145a6ab6",
                "a690ba198e52db7e"
        "id": "32fa05f1e9c7c923",
        "type": "inject",
        "name": "Fake Data",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "56",
        "payloadType": "num",
        "x": 400,
        "y": 360,
                "a8c1d9281aea0673"
        "id": "2b5a428a194e0fc4",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1050,
        "y": 280,
        "id": "133e8899145a6ab6",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "listeEtuves",
                "pt": "global",
                "to": "tab",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 860,
        "y": 360,
                "2b5a428a194e0fc4",
                "16e8c2f9e428e79c"
        "id": "a690ba198e52db7e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 830,
        "y": 280,
        "id": "4cc7ebb845e3a096",
        "type": "telnet-send",
        "connection": "27ace6a62991b9b0",
        "x": 1230,
        "y": 360,
        "id": "a4df93d5b4be84e1",
        "type": "telnet-read",
        "connection": "",
        "x": 1230,
        "y": 420,
                "e1a6047482ce5f0e"
        "id": "e1a6047482ce5f0e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1390,
        "y": 420,
        "id": "16e8c2f9e428e79c",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "10",
        "timeoutUnits": "milliseconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1070,
        "y": 360,
                "4cc7ebb845e3a096"
        "id": "27ace6a62991b9b0",
        "type": "telnet-connection",
        "address": "127.0.0.1",
        "port": "23",
        "inDelimiter": "",
        "outDelimiter": "",
        "timeOut": "1500",
        "clearOut": "",
        "openTries": "1"
I am still a beginner in Javascript, so maybe there is a more efficient way to do this function.
Thank you for your help :slight_smile:
Hi, I come back to my previous message.
In fact, due to the impossibility to inject dynamical variables, I can't factorise the code like I wanted. The solution I've found is to create send and read data nodes for each chamber. However, the processing of data can be done in a subflow in order to shorten the code. The problem is the using of global variables in the subflow. I noticed that the values for both chambers are well read, but they are replaced when the same parameter is read of the next chamber. For instance, I would like to print the pressure value of the first and the second chamber. In my case, it prints first :
"Chamber 1 : 10.09"
"Chamber 2 : 10.09"
And then :
"Chamber 1 : 13.49"
"Chamber 2 : 13.49"
I would like to get :
"Chamber 1 : 10.09"
"Chamber 2 : 13.49"
Do you know how can I fix this problem ? I did one processing for each chamber, so I thought it will give me the value for each one. But apparently, it is not the case. Here is an idea of my flow.
In the subflow, I only have a change node which sets a global value for one parameter.
I hope it was clear, but I definitely think that the problem comes from global values.
Flow :
        "id": "2c411b946746dd66",
        "type": "subflow",
        "name": "Subflow 1",
        "info": "",
        "in": [
                "x": 380,
                "y": 280,
                        "id": "f22cb29dee88cede"
        "out": [
                "x": 880,
                "y": 280,
                        "id": "f22cb29dee88cede",
                        "port": 0
        "type": "change",
        "z": "2c411b946746dd66",
        "rules": [
                "t": "set",
                "p": "Etuve.MHpPrinc",
                "pt": "global",
                "to": "msg.payload",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 280,
        "id": "2e1fb91b064e0dbb",
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "id": "8e3b11bfdc086999",
        "type": "inject",
        "z": "2e1fb91b064e0dbb",
        "name": "Fake data",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "10",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "56",
        "x": 510,
        "y": 440,
                "a05f0162842cae4d",
                "40088b6b39ea021c"
        "id": "40088b6b39ea021c",
        "connection": "8a3cd99875508432",
        "x": 750,
        "y": 380,
        "id": "5b1dc18d931f5d53",
        "x": 1010,
        "y": 380,
                "5fa05bac2447ebfe"
        "id": "a05f0162842cae4d",
        "connection": "1834e5b8655e71f1",
        "x": 750,
        "y": 520,
        "id": "35d4f0aaad4e1ed6",
        "x": 1010,
        "y": 520,
                "ca8f57ae883f8f1b"
        "id": "6ffbf644f4de15a4",
        "type": "debug",
        "name": "Chamber 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1390,
        "y": 380,
        "id": "bc9e4410b64aac46",
        "type": "debug",
        "name": "Chamber 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1390,
        "y": 480,
        "id": "f1b525c41d22ab3c",
        "type": "ui_text",
        "group": "7b5442934adeb0ca",
        "order": 1,
        "width": 6,
        "height": 1,
        "label": "MHpPrinc 1",
        "format": "{{msg.payload}}",
        "layout": "row-center",
        "className": "",
        "x": 1390,
        "y": 420,
        "id": "74258a789825c2c3",
        "type": "ui_text",
        "order": 1,
        "width": 6,
        "height": 1,
        "label": "MHpPrinc 2",
        "className": "",
        "x": 1390,
        "y": 520,
        "id": "ac54dc8d04b57ac6",
        "type": "comment",
        "info": "",
        "x": 880,
        "y": 380,
        "id": "75b10e05ba2ef27c",
        "type": "comment",
        "info": "",
        "x": 880,
        "y": 520,
        "id": "5fa05bac2447ebfe",
        "type": "subflow:2c411b946746dd66",
        "x": 1180,
        "y": 380,
                "6ffbf644f4de15a4",
                "f1b525c41d22ab3c"
        "id": "ca8f57ae883f8f1b",
        "x": 1180,
        "y": 520,
                "bc9e4410b64aac46",
                "74258a789825c2c3"
        "id": "8a3cd99875508432",
        "port": "23",
        "inDelimiter": "",
        "outDelimiter": "",
        "timeOut": "1500",
        "clearOut": "",
        "openTries": "1"
        "id": "1834e5b8655e71f1",
        "address": "127.0.0.2",
        "port": "23",
        "inDelimiter": "",
        "outDelimiter": "",
        "timeOut": "1500",
        "clearOut": "",
        "openTries": "1"
        "id": "7b5442934adeb0ca",
        "type": "ui_group",
        "name": "Group 1",
        "tab": "81690565567bb45b",
        "order": 1,
        "disp": true,
        "width": 9
        "id": "81690565567bb45b",
        "type": "ui_tab",
        "name": "TEST",
        "icon": "dashboard",
        "order": 5,
        "disabled": false,
        "hidden": false
Your subflow is completely meaningless - it sets a global variable and nothing more
It is the payload value from these read nodes that set your UI elements.
that should be evident by the output of the debug nodes.
Thanks for your reply.
I put only one value in the subflow for the example, but there are many others variables in my real flow. I also do some processing within it. That is why I created a subflow. There are multiples payload within it. Otherwise yes, the subflow would be meaningless.
This is an extract of my subflow. As you see, I define a global name for each parameter. For instance, I defined Etuve.MHpPrinc, then I send the value by MQTT. Doing that within the subflow, I thought it will give me the value for every chamber, because their is one subflow linked to one chamber (see flow).
I can't achieve to print the value of Etuve.MHpPrinc for the chamber 1 and 2 separately, it's either 1 or 2.
Does it more clear ?
output 1 will be triggered for EVERY subflow.
either move the MQTT stuff out of the subflow OR test the topic using a switch node AFTER the subflow.
